buying used g35 sedan 6speed
Old Sep 7, 2011 | 12:52 AM
christiankirana's Avatar
Hi, I'm looking to purchase 2004 G35 sedan 6 speed. Anything that I should check before purchasing it? Besides car history check. As I am preety new towards G35. Thanks..
Old Sep 7, 2011 | 03:06 AM
ray1370's Avatar
Welcome to Driver! Questions on purchasing 03~06 6MT have been brought up a few times before, do a search in sedan section you should be able to find them. Here's the answer I gave in a similar thread:
OP, here are the major issues I had with my 03.5 6MT:
- bad synchros in tranny causing grinding when shifting into 2nd~6th gear
- valve cover oil pooling issue
- compression rod bushing issue
And if you get the car you might need these services soon:
- clutch and flywheel replacement
- spark plugs
- compression rod/lower control arm bushings
- shocks and struts
- wheel hubs and bearings
Get the VIN# and check the service history from Infiniti before you make your decision.
Good deal for 6MT sedan? Need advice from the G35 driver GURUS!
Good luck!
Old Sep 7, 2011 | 10:32 AM
LRg626's Avatar
make sure the back seats recline lol i traded my coupe for 04 sedan ob 6mt...test drive the car...for 15mins....and make sure it drives straight...
vmcarbuyer
Oct 12, 2019 12:42 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
Karnicle
Jul 23, 2015 05:08 AM
