HP Blues with Tein S-techs
Old Sep 18, 2011 | 05:17 PM
jimmyboi860's Avatar
Thinking of buying these....what do you guys think of this set up?
Old Sep 18, 2011 | 05:19 PM
i just hit 90k, i'm in need of strut replacement. I also wanna lower the G as well...what do you guys think or a recommended set up?
Old Sep 18, 2011 | 05:36 PM
JaE35's Avatar
Moderator
G35 Sedan
would be a good setup, get the ones made for the 350z
Old Sep 18, 2011 | 05:46 PM
Ride quality is better with the 350z ones?
Old Sep 18, 2011 | 05:47 PM
JaE35's Avatar
Moderator
G35 Sedan
will be the same, 350z ones will get you an additional 1/2" lower
Old Sep 18, 2011 | 05:49 PM
JaE35's Avatar
Moderator
G35 Sedan
then you can get 350z s-techs like me and enjoy the much better spring rates
Old Sep 18, 2011 | 06:56 PM
So 350z HP blues, with the 350z s techs? So the car would drop around 2" then? That's not bad at all.
Old Sep 18, 2011 | 06:59 PM
JaE35's Avatar
Moderator
G35 Sedan
Yea somewhere around there, you can check out the drop on my car in my garage...just ignore my rear flared fenders, i was running wider rims a while back
Old Sep 18, 2011 | 07:04 PM
Nice. Says you have a camber kit too, would I need this? Or were you preparing for coils?
Old Sep 18, 2011 | 07:12 PM
JaE35's Avatar
Moderator
G35 Sedan
Yea you'll need a rear camber kit, mandatory...after the drop i was almost -4 camber and eating through my tires before i got one...front can still get in spec without one
Old Sep 18, 2011 | 07:14 PM
So recommend getting a rear camber kit? Spc one then if i do
Old Sep 18, 2011 | 07:15 PM
And thanks appreciate the advice.
Old Sep 18, 2011 | 07:16 PM
JaE35's Avatar
Moderator
G35 Sedan
yea you will have to get one, and definitely spc
Old Sep 18, 2011 | 07:23 PM
ok so im going to order 350z hp blues, with 350z s techs, and spc rear cambers. correct?
Old Sep 18, 2011 | 07:24 PM
JaE35's Avatar
Moderator
G35 Sedan
exactly, you may be able to find those springs used over on my350z for 100 bucks less unless you want new
