Wheels
Old Sep 20, 2011 | 05:25 PM
bluedevils95's Avatar
If your afraid to buy them right away you can always test fit it to see if you like it on your G.
Old Sep 20, 2011 | 06:21 PM
4D05G35's Avatar
Wheels-photofs2.jpgHere are a few from my phone.
Old Sep 20, 2011 | 06:22 PM
shawndon's Avatar
I suggest not going any larger than 255/35 in the rear. My offsets are 20x8.5 +5 and 20x10 +18 and I am at -5 on camber. Tire sizes are 235/30 and 255/35. If I had to pick rears again I would go with a 245/35.
Old Sep 20, 2011 | 10:19 PM
007JD's Avatar
how about if u have 40 offset rear 20x10 ? .. can u run 275/30/20 ??
Old Sep 21, 2011 | 06:38 AM
shawndon's Avatar
Depends on how low you want to be and what look you are trying to achieve. If you want to go low that rear size will be too large.
Old Sep 21, 2011 | 03:24 PM
007JD's Avatar
i want to be sort of low not slammed.. but that the drop is noticeable
im guessing that with that setup 40mm offset n 20x8.5n20x10 with 245/35 n 275/30
is not going to get me low enough ?
Old Sep 21, 2011 | 05:50 PM
shawndon's Avatar
You wont be able to go that low in the rear and not rub with the 275. But you can still lower it nicely. You also wouldn't want a 40 offset up front with an 8.5. I'd say more like 30.
Here is a pic of a car with 275/30 in the rear. I think the front may be 245/35 but not sure.
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
