Wheels
Old Sep 20, 2011 | 08:33 AM
rxdreams's Avatar
Wheels
Hi everyone I need a little help. I found some wheels and I would like to know if they would fit my 05 sedan. size Front 20 8.5 +20mm. tire is 245/35/20 and Rears are 20 10.0 25mm and tires 275/35/20 please let me know of modification if any. stock suspension. Thanks Chris
Old Sep 20, 2011 | 11:59 AM
007JD's Avatar
those are coupe offsets..
usually sedan offsets are 30-40 give or take
im not sure.
people run 0 offset im pretty sure u can fit it
i kno 20x8.5 n 20x10 with those tires can fit .
roll fenders and drop .
Old Sep 20, 2011 | 12:07 PM
rxdreams's Avatar
I know they said they came from a 350z. Im just hoping they wont stickout.
thanks for your input
Old Sep 20, 2011 | 12:11 PM
007JD's Avatar
lol will if you going for that aggressive look . after modifications u can prbly do it..
ask 4dgs, or stimulation or ttrank or someone there the guru for wheel spec
they will or someone will chime in 2 better assist u
Old Sep 20, 2011 | 12:21 PM
007JD's Avatar
i did some searching ...
and found this
they CAN work, but not with those tire sizes.
You'd need to have atleast a 2" drop and -2 camber with 235/255 tires
-GP-
by gdupsedan
but ppl was saying dont go that low on offset ..
use the search .. n type in offset and read around
Old Sep 20, 2011 | 12:38 PM
94z28joe's Avatar
I have 20X8.5 with +15 up front and 20X9.5 with +20 in the rear my wheels are pretty much flush. stockish camber on 350z revised springs.
Old Sep 20, 2011 | 12:42 PM
007JD's Avatar
what size tires n pixs?
Old Sep 20, 2011 | 12:43 PM
CandlestickPark's Avatar
ill Sedan
Those will fit but you are going to need a drop (coilovers would be highly recommended), some fender work, a bit of camber out back and smaller tires (for the rear, which would result in needing a smaller tire up front otherwise it would look weird) to make them fit.
Old Sep 20, 2011 | 01:29 PM
94z28joe's Avatar
tires are 235/35 front and 265/30 rear
Sorry for the image quality of the second picture I took it with my phone. Car is sitting a high in the front in the first pic due to the incline of my driveway. it sits much lower then that on flat surfaces.
Old Sep 20, 2011 | 01:48 PM
007JD's Avatar
r u on stock height?
Old Sep 20, 2011 | 01:49 PM
rxdreams's Avatar
kool pic, same color as mine. well I was thinking about getting them wheels cause they were pretty cheap. now i know where i stand bout sizes and offsets. thanks
Old Sep 20, 2011 | 01:50 PM
rxdreams's Avatar
everything stock!!
Old Sep 20, 2011 | 01:52 PM
94z28joe's Avatar
my car is lowered on revised 350z springs
Old Sep 20, 2011 | 03:11 PM
4D05G35's Avatar
Like others have said.
You will need to roll your fenders and depending on how flush you want to be, a slight pull. you are going to want to change the tire sizes as well.
I was rolled flat with a slight pull with similar wheel specs. 20x9 +18 and 20x10 +25 with 225/35/20f and 255/30/20r. I was dropped about 2" with -2 degree's of camber. No rubbing.
Old Sep 20, 2011 | 03:51 PM
007JD's Avatar
^^ pixs my good sir ??
