Need help engine question
Old Sep 25, 2011 | 11:01 AM
thescreensavers's Avatar
Mr.202?
Originally Posted by bigjee
Yup. That and the fact thst it is perfect for the winters here as it reaches 40 below on some days here. Oh and it's a 0w oil and not 5w.
But yeah although amsoil brags higher mileage (25,000 km with their filter)I'll just stick with the GC.
lol yea meant 0W, when it thickens up its almost a 40wt., And thats all BS no oil can go 25k km just out of the box. Its more complicated then that. You need Used oil analysis with TBN. But you start at checking it at like 7500 km and go up from there.
Old Sep 25, 2011 | 11:54 AM
DaveB's Avatar
The reason the heads have to come off is because you need the ring compression tool to sit flush with the top of the block has you tap the assembled pistons into the block. You can't do that from the bottom because the surface is not flat due to the crank journals and the casting of the lower portion of the block.
jsimonk
Dec 22, 2023 03:49 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
