Need help engine question
I was talking to a friend about putting new rings in a spare VQ35DE non revup he has. Somebody told me that to re-ring a VQ the heads would need to be removed. So my question is is there any truth to that statement? and if so why do the heads need to be removed? I assumed the rotating assembly could come out with removing any topend components other than the timing chain. Somebody help LOL do the heads need to come off to do rings if so why?
Thanks in advance guys
If you mean piston rings then yes the heads have to come off. Is there any particular reason you're going in for just the rings? Once the heads are off it's a good opportunity build up your motor better than new!
I have a bad engine in my g this engine has less than 20k and needs rings my bank at this point doesn't really allow for a build....honestly I look at my g as a bolt on car I don't ever see myself boosting it or looking for high power so stock internals are fine for my goal with this car...I enjoy the car as it is and need it in running condition asap...if I ever wanted to do a build I will have the engine that's in the car now to do that with
That's where I made my mistake...I didn't think about it at all before I questioned it.....im kind of embarassed...if I would have thought about it at all I wouldn't have ever had to ask..thanks though guys
Its cool! No worries. At least you are man enough to admit it lol. You just earned yourself a friendship!
Lol not even learn....just realize what you already would have known if you thought for a second...well I guess I learned to think a little bit more before I ask
If oil consumption is a concern, even to an extent, in a non-revup engine, would Maxima pistons and rings be better for oil control and cheaper than Infinitis. The reason I ask is that my '05 Max does not use any oil between 10k mile changes of Amsoil 5w-30. My only uncertaity is- are they interchangeable?
My '06 G take about a quart between changes.
If oil consumption is a concern, even to an extent, in a non-revup engine, would Maxima pistons and rings be better for oil control and cheaper than Infinitis. The reason I ask is that my '05 Max does not use any oil between 10k mile changes of Amsoil 5w-30. My only uncertainty is- are they interchangeable?
Switched oil to GC synthetic and it stopped consuming oil.
Im sticking to German Castrol syntec from now on.
But yeah although amsoil brags higher mileage (25,000 km with their filter)I'll just stick with the GC.
