Someone please help!!
Old Sep 23, 2011 | 09:58 AM
jewelz34's Avatar
Hey guys i drive an 03 g35 6mt and u have trouble starting my car. My key wont turn it the ignition at all and it seems that the steering wheel is locked as well. Believe me i spent at better part of my day trying to unlock it. A few week prior my car was making that beeping noise as well. The noise representing that your door is open and key in the ignition, but this time there was no key in the ignition but the door was opened. In order for me to stop the beeping noise i had to 1. close the door 2. put the key back in the ignition or 3. put my finger around the ignition hole and wiggle it a bit.
Please leave me some feedback on what it may be or what i should do. Thanks
Ps excuse the grammar
Old Sep 23, 2011 | 10:01 AM
007JD's Avatar
does it let you turn the key ??
if it doesnt then
sounds like key ignition pooped
mayb the lock inside the key ignition got locked inside.
(happen to my accord)
but can prbly be something different.
Old Sep 23, 2011 | 10:04 AM
jewelz34's Avatar
if it doesnt then
Ya doesn't let me turn it at all. just been sitting in my drive way for a couple of days lol.
Old Sep 23, 2011 | 10:08 AM
PAIXAO's Avatar
Sounds like it's time for a new ignition. This is going to be a pain in the @ss for you because the new key will need to be programmed by the dealership. I would try your second key before doing anything else.
Old Sep 23, 2011 | 11:02 AM
ccc123pm's Avatar
X
It sounds like the beeping and the key issue are separate. As far as the steering wheel and ignition issue, this has happened to me in a couple different cars and has happened to me once or twice in my infiniti, and usually happens if you parked with the steering wheel not on center. In the past i have turned the steering wheel further away from center and used a little more force in turning the key. might be worth a shot
Old Sep 24, 2011 | 03:35 PM
jewelz34's Avatar
thanks for everyone with their help. Got it fixed. Lock smith came over and said the pins seemed to be stuck, which made it difficult to turn my key. So he got the pins loose again. Cost me about 81 bucks to fix
Old Sep 24, 2011 | 04:27 PM
nawalvicky's Avatar
dam that was some honest locksmith... now a days people will say anything just to make a buck. People by where i live will tell you the whole cylinder is jamed. Needs to be removed blah blah blah and try and charge you an arm and a leg. Smh. congrats on getting it fixed and at a resonable price.
