Push button start anyone?
Old Sep 24, 2011 | 07:35 PM
funnyscreenname's Avatar
Just wondering if any member have push button start added to their car either from aftermarket or rigged from another Nissan with push start. I thinking it'd be great to find one that could easily be swapped into my 05 and it look oem.
Old Sep 24, 2011 | 08:04 PM
Mustang5L5's Avatar
It would not be easy to retrofit the OEM system.
There are aftermarket systems, but they are expensive and you would still need to put the key in, turn it to ON, and then hit button. At that point, just turn the key another 1/16 turn.
Old Sep 24, 2011 | 08:58 PM
Yea I'd want the button to actually function without use of the key. Just get in and go. Oh well. Just a thought....for now.
Old Sep 24, 2011 | 09:00 PM
Mustang5L5's Avatar
Well, the OEM 05/06 system is not technically push button. You have a **** that you turn, but you don't need to insert a key. So to put in an OEM system would require a lot of special parts.
Aftermarket systems are pricey and I've only seen them installed on older cars with much less complex security/ignition systems
Old Sep 24, 2011 | 10:36 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
I saw a thread where a member actually pulled it off, he had to sacrifice a key that sat in the ignition permanently. Search for it, I'm sure you could find it.
RemmyZero
Aug 22, 2015 11:38 AM
Frostbite91
Aug 20, 2015 07:20 PM
ev_g35
Interior
Aug 14, 2015 02:05 PM
FRUG35
Aug 9, 2015 07:55 AM
.cakestar
Aug 4, 2015 09:05 PM
