VDC and ABS are all screwed up!! Please help
Old Oct 1, 2011 | 05:10 PM
Beebo's Avatar
Guys my ABS and VDC lights are on andf the VDC Off light is on as well. now all my navi says is that the ABS are not functioning properly. also the bracks are squeky when stopping nut all pads and rotors are fine. so since i have a BBK i thought i just had to top off the brake fluid since its normal to do so every few months but when i checked the master cylinder it was full. idk what the problem is any ideas?
on a side note the car fish tails way to easy now and the rear tires just spin
Thanks for any help,
-Wes
Old Oct 1, 2011 | 05:16 PM
bigjee's Avatar
Gotta get that code.
It'll let you know what part is screwed up rather than to look in places that are the probable cause.
The code will tell you exactly whats acting up.
Old Oct 1, 2011 | 05:19 PM
Beebo's Avatar
I cant get the code till Monday and the car is my daily
Old Oct 2, 2011 | 07:28 AM
Blue Dream's Avatar
I drove ttrank's car solo
Wes do you happen to have the SPC front camber kit? If so have you hit any big bumps or jarred your front end significantly lately? I've heard of the small ABS sensor bracket on those arms either breaking or shifting position and causing the idiot lights to trigger.
Sorry I missed you on the way home, we'll get together someday.
Old Oct 2, 2011 | 08:11 AM
Dubi2087's Avatar
Your Diff also has a to sensors that work as your speed sensor and your ABS check those out and make sure they are on correctly. If not they will trigger your lights to come on.
Old Oct 2, 2011 | 11:17 AM
Beebo's Avatar
yes i have the SPC V1 front arms they hit all the time
ill have that checked out
Old Oct 3, 2011 | 03:09 AM
Beebo's Avatar
Now my cruise control wont work... :/
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
markbilo
Sep 30, 2015 01:33 AM
