Radio/Climate Cotrol issue...PLZ help cus I don't get it
Old Oct 8, 2011 | 12:13 PM
equilibrium's Avatar
I am still about to open it up, but I have a 2003 G35 sedan with the all famous radio ac controls problem.
I am searching and searching for last two days on the forums, and all I want to know is this:
There is a circuit board that fails that controls both the HU and the Climate controls.
Now if I buy just the climate controls, where does that hook up to?
Let's just say I don't want a radio, I just want the DD Kit with the AC controls! Now that the stock HU and the stock board is removed, where does this new AC control plug in?
I hope you understand my question, because I am a little confused: if you have the stock HU the AC controls are in the same board as the HU, but if you buy a DD kit with the AC controls, then where does the AC controls plug in!?
Thanks!
Old Oct 8, 2011 | 01:47 PM
AARONHL's Avatar
There is a separate plug for each the climate control and radio boards.
Old Oct 13, 2011 | 02:02 PM
Obsidian Sport's Avatar
I ordered and installed the replacment audio finisher board from Infiniti, only to have the problem persist. I pulled the stereo head unit and sent it into these guys:
http://www.carstereohelp.com/infiniti.htm
Upon return, re-assembled everthing and it's been working fine since. I read a million posts and theories about the issue, but I can attest that it is your stereo, although i suppose it can't hurt to install the "new" finisher board to prevent recurrence. BTW, there is a ribbon cable connecting the finisher board to the Bose unit, if that's what you were asking.
Old Oct 13, 2011 | 02:11 PM
also, sorry - can't help or comment on the DD option or bypassing your stock HU, as i found repairing it back to stock to be the easiest and most reliable fix personally.
Old Oct 13, 2011 | 02:18 PM
GR6RR's Avatar
the ribbon, try and trim it...
or if that dont work, JDM DD Finisher with Controls is what you WILL need.
Jiggerjuice
Oct 5, 2015 02:33 PM
cmesidewayz
Sep 29, 2015 09:28 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
