Tranny fluid first service
Old Jan 6, 2006 | 09:49 PM
RBull's Avatar
Rated M
Originally Posted by DaveO
I agree that a correctly done AT flush and refill isn't a bad idea, especially if you drive hard or anytime the ATF's color and/or smell is questionable. That said, a flush and refill may not be necessary for many Gs until they get above 60k miles.
The maintence schedules in the 03 and 04.5 Factory Service Manuals indicate all that's needed for automatic transmission fluid and manual transmission gear oil & differential gear oil is an inspection at 15k, 30k, 45k, 60k miles, usless... see NOTE: (1).
"NOTE: (1) If towing a trailer, using a camper or a car-top carrier, or driving on rough or muddy roads, change (not just inspect) oil at every 30,000 miles (48,000 km) or 24 months. Using automatic transmission fluid other than Genuine Nissan Matic J ATF will cause deterioration in driveability and automatic transmission durability, and may damage the automatic transmission, which is not covered by the INFINITI new vehicle limited warranty."
I highly recommend changing out the rear diff fluid much earlier. I did mine at about 6k miles and it was a nasty dark grey and the magnet had a 1/4" coating of metal all over it.
Old Jan 9, 2006 | 01:10 PM
Jeff92se's Avatar
Red Card Crew
Anyone??
Originally Posted by Jeff92se
How does one even "inspect" the AT fluid? There's no stick!
f22raptor
Mar 18, 2016 08:50 AM
AL8782
Oct 3, 2015 10:26 AM
