Fix loose leather on door panel
Old Jun 27, 2013 | 10:39 AM
MikeDG's Avatar
The leather on my passenger side rear door panel has separated around the concave portion in the center. It looks like I have a bubble in the panel. How are you guys spraying the adhesive to the back of the leather? Is the leather insert removable from the door panel or do you have to peel back the leather?
Old Jun 28, 2013 | 08:31 AM
Blue Dream's Avatar
I drove ttrank's car solo
I would suggest poking a small hole in the leather in the middle of the bubble (in one of the recessed squares) and injecting the glue into the hole. Or you can peel the leather from the plastic backing if it will come off, but that seems extreme for what you have. The back of the leather has a foam backing as mentioned above so the right adhesive is a must.
I wouldn't try Gorilla glue like someone said as it greatly expands when it dries leaving what I would suspect a less than smooth final result.
Old Jul 23, 2013 | 10:36 PM
vipjd39's Avatar
i used the 3m
Old Jul 24, 2013 | 04:50 PM
RADIOGUY21's Avatar
My drivers door was doing the same. I used some leather/vinyl epoxy and a credit card to wedge it back into place.
Old Jul 29, 2013 | 06:33 PM
X-Rated's Avatar
this is happening to my driver and passenger door panels, this is great im probably going to go with the Gorilla glue and small paint brush seems the least messy and then i'll wedge with a credit card.
Old Jul 30, 2013 | 12:05 AM
Wi-Z_Sam's Avatar
Make sure you smooth out the glue quickly, I have a few bumps on the first door I did and it looks kinda crappy
Old Aug 8, 2013 | 05:40 PM
anbeyond's Avatar
Thats funny. Mine just started falling off also.. I put Krazy glue on it an it held so far.
Old Aug 8, 2013 | 09:18 PM
joedaddy1's Avatar
can someone post a picture of this issue?
thanks!
Old Aug 9, 2013 | 03:17 AM
X-Rated's Avatar
Anyone know what will give the best smooth finish ?
Old Aug 10, 2013 | 08:16 AM
Budking94's Avatar
They have a leather and vinyl glue that is made by Loctite ...looks like a small super glue bottle
Old Aug 10, 2013 | 08:18 AM
Budking94's Avatar
Joe daddy how do you know if your car is a 2003.5? I just bought a 2003 g.
Old Aug 10, 2013 | 10:22 AM
joedaddy1's Avatar
by the trunk,no doggie door = 2003.5
I know there are other differences, but seems like that's the easiest way..
but overall.. i don't think it's a big deal.
Old Oct 3, 2013 | 09:56 PM
bocatrip's Avatar
My girlfriend's 06 G35 sedan has the same problem with both front door panels peeling back. I believe the only permanent method is to peel back the material and respray with the proper adhesive for vinyl and foam. I'm having an upholstery shop do it. I'll report back on the results after it is done.
Old Oct 4, 2013 | 10:35 AM
wasjr's Avatar
Recently bought an 03 Sedan and it is interesting that the issues with my car are very common with this vehicle. The rear passenger door had this issue and the previous owner had botched the repair. About 1/4 of the panel was hanging and the rest of the panel was loose in several places. Took it to an upholstery shop and since new leather had to be used it cost $125 (it would have been $90 if the previous owner had not botched the fix).
Also, the leather cushioned cover on the upper glove box (no navigation) had warped and was loose. The shop re-glued it, but told me that since the cover is so stiff and warped it probably would not hold. They were right. Door is still functional. Priced new door but it comes in a group that is $400. May try salvage yards.
Old Oct 5, 2013 | 07:01 PM
  #30
Turtles_ride's Avatar
$5 for spray adhesive, non vlatile so the foam doesn't get melted, mine sprayed out blue. Peel back as much of the sponge and leather as you can to get the glue deep on the door panel and the spongy leather back. The key is to keep them apart until the spray glue starts to dry, thats when it will stick most permanently, then pull the leather up and tight so that you have lots to push up under the top of the door panel, push on and smooth by hand. You may want to stick something between the leather and door panel top to keep the leather from pulling back down until it dries good. Did all 4 of my doors 2 years ago, even tho only 2 needed it, with the panels still on the car, and they haven't come apart again yet, concave part on the rears has even stayed stuck in place.
