shocks and struts
Old Nov 6, 2011 | 12:26 AM
Carrottop401's Avatar
shocks and struts
2004 g35x 103k.. basically stock . my question is what kind of shocks and struts do you guys use? i dont plan on lowering my car . this is my everyday car so i want a mix of a smooth ride and good handling...
Old Nov 6, 2011 | 11:19 AM
Blue Dream's Avatar
I drove ttrank's car solo
Tokico HPs are a popular choice on here. For a little more you can get their "D Specs" which will offer adjustable dampening as well.
Old Nov 6, 2011 | 12:19 PM
any specific website i should get these off of?
Old Nov 6, 2011 | 05:20 PM
drkay's Avatar
there are no aftermarket struts/shocks for the front of the 04 AWD. the rear RWD and AWD shocks are the same tho, so aftermarket is available for the rear only. . .
Old Nov 6, 2011 | 06:49 PM
so what are my options for the front? so this would mean there are no aftermarket coilovers for the front also?
Old Nov 6, 2011 | 07:30 PM
FlyingLumpia's Avatar
There are 3 choices for coilovers. BC Racing, Megan, and I guess Ksport just made some. If you want to you can send your fronts to truechoice where they will make it into a koni strut. The price of is just about the same as the coilovers and that is just for the front.
Old Nov 6, 2011 | 07:46 PM
ccc123pm's Avatar
X
KYB makes front struts for awd, an economical alternative to factory struts
Old Nov 7, 2011 | 12:11 AM
The KYB are oem replacements they wont do much for aftermarket. But yes if you want to just replace them they will be the way to go.
Old Nov 7, 2011 | 12:14 PM
drkay's Avatar
according to the KYB website (http://www.kyb.com/pdf/kyb_catalog.pdf) they do not make struts for the 2004 AWD
there are coilovers available for the 2004 AWD, forget the company tho
Old Nov 7, 2011 | 12:49 PM
Mustang5L5's Avatar
I kinda want struts/showcks for my '06x next summer as well.
So, is OEM the only option? I don't want coil-overs or any sort of performance shock. Just want a cozy ride.
Old Nov 7, 2011 | 06:48 PM
drkay's Avatar
KYB does make OEM replacement front and back struts for the 05x and 06x, just not the 04x
Old Nov 7, 2011 | 08:41 PM
The 05-06 is the same as 04 they will work
Old Nov 7, 2011 | 08:51 PM
drkay's Avatar
is that also true for the AWD?
i hope you're correct and the KYB fitment guide is wrong, as i will also be needing new struts soon. . .
Old Nov 7, 2011 | 09:52 PM
coilovers or shocks and struts?????
Old Nov 7, 2011 | 11:40 PM
Why would the coilover companies use the same part number for the 04-06, funny thing is that they used the same coilover for the 04 for the 07 awd. I am 100% sure that they will fit.
Carrottop what are you looking for. What is your budget. How low do you want to go?
