Driver Side Window issue -- reset not working
Old Nov 10, 2011 | 04:13 PM
JamesN's Avatar
I tried these 2 procedures;
http://infinitihelp.com/diy/gcoupe/p..._procedure.htm
http://forums.nicoclub.com/faq-or-di...t-t461334.html
Neither is working.
Background.
The window motor went out so I replaced it per the wiki. The window motor now goes up and down. When I put it up, it auto goes down about 5"s. The only way to keep it closed is to hold the up switch for about 5 seconds.
One interesting observation... I can not keep the window closed even with the door open. It will always drop ~5" unless I hold the switch as previously mentioned.
Any suggestions?
Old Nov 11, 2011 | 05:16 PM
JamesN's Avatar
I got the window to stay up with no issues now.
However the motor reset procedure is still failing.
I pulled off the rubbed covering the "button" on the old motor and there is no button under it.
Old Jan 31, 2012 | 08:56 PM
RKturbo6's Avatar
I am having this same issue after replacing the drivers motor. Tried reseting it 10 times and still the same thing. Soon as I close it, it will close then go back down 5 inches or so. Driving me nuts. Anybody have anything on this would be greatly appreciated.
Thanks
Old Jan 31, 2012 | 10:31 PM
01yellowr's Avatar
I had the same issue with my old G20. I ended up taking it to the dealer and having them fix it. Cost me an hours labor but it worked
Old Feb 1, 2012 | 09:44 AM
04nismoG's Avatar
You would have to take it to the dealer. I had the same problem our cars window run off of some computer in the car, after you replace the motor the computer has to be recalibrated for that motor not just reset. I had replace three motors with in three months. I took it to the dealer and had them recalibrate the window computer no more problems for over two years now.
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
vstypicals
Jul 20, 2015 10:55 PM
attarday
Jul 15, 2015 04:03 PM
