May be officially joining! Help inspecting 05 please, going tomorrow
Old Dec 4, 2011 | 05:37 PM
tunermaxima3000's Avatar
had a '97 5speed, now have a 2001 Anniversary DE-K.
Had a 2003 with the 3.5 and 6speed for a short while but the engine was junk.
In either case, I love the way the G drives in comparison, RWD and a much better turning circle are the biggest pros in comparison to a 3.5 maxima.
I have mixed feelings about the rear end (sedan) appearance though, but seeing what some of you have done to make them look good temps me. The 03/04 is just ugly though IMO
Old Dec 4, 2011 | 05:40 PM
Songle6MT's Avatar
Originally Posted by AARONHL
You'll hear a whining noise coming from the gearbox before the fluid is fully warm. Usually happens after the car has been sitting a few hours in <50 degree weather. Sounds similar to a window air leak.
https://g35driver.com/forums/brakes-...6mt-coupe.html
Also, your third gear will grind a little so be gentle with it. And prepare yourself to go from 1 to 3 when it's cold..forget about second gear...
At least i'm not the only one with this problem..
I have a helluva time getting this car into second when it's cold, and it always seems to grind second and third
Old Dec 4, 2011 | 08:19 PM
Crappy part is you need 2nd the most when it's cold! At least when it's slick out
Old Dec 4, 2011 | 08:52 PM
bigjee's Avatar
I've heard that mixing the two transmissions fluids 50/50 (equal parts of manual fluid and auto fluid) alleviates the issue.
Has anyone given that a try?
Old Dec 5, 2011 | 09:09 PM
^I wouldn't do that, probably kill the sychro's faster. GL-4 or GL-5, Amsoil is my preference. I've heard switching to quality fliud helps most people out. Also in older trannies poor worn shift linkages were a big factor too. The main cause is just a crappy Nissan Tranny design.....Can't be permanantly helped really.
I always found double-clutching was the easiest way to get it into 2nd when cold.
g.spot
May 9, 2016 10:54 PM
corynooooo
Sep 26, 2015 10:54 AM
