should i get 18s or 20s?
Old Dec 6, 2011 | 03:41 PM
4D05G35's Avatar
Originally Posted by Roh
i'm looking for a semi agressive look, its still my dd so i don't want anything to crazy, so with the offsets, 43+ for the rear and 35+ would work?
and i want a little stretch on the tires as well so wouldn't i have to go smaller then 285rear and 245front for the tires?
if i do get the camber kit, do i need any supporting parts with it or just the camber kit itself? i would like it to look something like this in the end
sorry for all the questions ! i've done my research but i still rather ask the people who know more lol thanks again!
The specs you have will work fine.
If you want a little stretch and flush you could go with 255/30/20R and 225/35/20F but you will want/need about a 15mm spacer front and rear. With natural camber up front and abut 2 degree's in the rear with the fenders rolled flat. You would need a camber kit for the rear with toe bolts.
Old Dec 6, 2011 | 09:19 PM
Roh's Avatar
Roh
alright perfect! thanks for the help! i just wanted to make sure about the offsets, 43+ for the rear and 35+, would work because i wasn't to sure about those.
Old Dec 6, 2011 | 10:47 PM
Carrottop401's Avatar
nice rims , are u also purchasing tires??? where do u plan on buying? i like these in black for my sedan...
Old Dec 7, 2011 | 01:50 AM
Roh's Avatar
Roh
thanks man, ye im gonna be buying tires as well but separately, prolly from 1010tires because they are set in canada or either a local place.
I liked the black ones but they don't come with a chrome lip and i didn't want all black so i decided to go with the ones that i posted! the silver ones will look good on a OB sedan.
Old Dec 7, 2011 | 08:08 PM
Antoniog35's Avatar
Nice wheels ! Were are you buying them from i cant seem to fined them online.
Old Dec 7, 2011 | 09:17 PM
4D05G35's Avatar
should i get 18s or 20s?-img_0480.jpgCrappy pics, but you get the idea hopefully.
Attached Thumbnails should i get 18s or 20s?-img_0163.jpg   should i get 18s or 20s?-img_0169.jpg
Old Dec 8, 2011 | 12:03 AM
Roh's Avatar
Roh
thats how i want it to look basically. the top is flush.
Old Dec 8, 2011 | 11:37 AM
007JD's Avatar
i got 20x10 n 20x8.5 40+mm offset for both with 245/35/20 n 275/30/20 falkens 452 with tein basic max dropped in the back
with rear camber n toe bolts.
ride quality at beg. was a bit rough and bumby .
after awhile you get used to it .. nothing major.
if you wana get flushed like thatt spacers.. gonna need spacers.
i ran my wheels n tires but no spacers
lmk if u wanna see pixs
Old Dec 8, 2011 | 12:23 PM
G35SedanGrn's Avatar
^post pics
Old Dec 8, 2011 | 12:57 PM
007JD's Avatar
https://g35driver.com/forums/g35-sed...5-d-build.html
i posted neew pixs
at the last pg
chck it out
Old Dec 8, 2011 | 01:04 PM
Roh's Avatar
Roh
i posted neew pixs
at the last pg
chck it out
the pics you posted on the last page were the ones with the 40+mm offsets right? looks nice!
ye if i was to go with 20+mm (rear) and 15+mm (front) it would poke out to far for my taste, i'd need to have prolly alota negative camber to make that flush.
It would be easier for me to go with 43+ rear and 35+ front. and add spacers if i want too.
Old Dec 8, 2011 | 01:32 PM
007JD's Avatar
yea 40mm wit no spacers front n back
i do have my rear fenders rolled flat tho (maxeed dropped in the back)
20/15mm are coupe offset .. i dont think ull b able to run those offset without heavy chngs u would have to do to your car.. im not sure..
Old Dec 8, 2011 | 01:42 PM
Roh's Avatar
Roh
ohkk makes sense, thanks for all the help guys! gonna order these new rims after christmas! just gotta make the decision on which color i'm going to get.
Old Dec 8, 2011 | 01:43 PM
CandlestickPark's Avatar
ill Sedan
That's a pic of my car that you posted. If are going for that look you are going for an aggressive setup not a semi agressive one.
My specs are:
19 x 9.5 +5, 225/35, -3.0 camber (natural camber from the drop OEM a-arms), fenders pinched flat naturally flared from rubbing
19 x 10.5 +18, 245/35, ~-5.5 camber, fenders pulled ~ 5mm
Old Dec 9, 2011 | 03:38 PM
  #30
05BlkG35Man's Avatar
My specs are:
Yep........that's aggressive. I think semi would be +20s.
