Some Help needed for a 1st timer
Old Dec 9, 2011 | 11:23 PM
  #31
Michael Joneser's Avatar
Have you tried to find any of your needed parts from ebay?
Old Dec 9, 2011 | 11:51 PM
  #32
mzenelji's Avatar
Yeah I have, most of them are pretty expensive, I' am also looking through the junkyard to see If i can pick up something for a bit cheaper, but if everything fails then I'll get it from ebay, but I' am still having a hard time finding the whole dash in the right color
Old Dec 10, 2011 | 03:29 AM
  #33
AARONHL's Avatar
That might be the best fitment after the drivers side got pulled out. The door and fender look original..did you look at the radiator?
Old Dec 10, 2011 | 05:14 PM
  #34
mzenelji's Avatar
I just pulled the front bumber out, going to be looking at the radiator this evening, trying to fix the headlight first
Old Dec 11, 2011 | 09:46 PM
  #35
AARONHL's Avatar
Post shots of the rear passenger side...looks repainted there too...wonder how much filler is on the rear quarter panel?
Old Dec 11, 2011 | 10:32 PM
  #36
mzenelji's Avatar
When I looked over the car, it seems like the whole car was repainted,
I'll take some pics here tonight and post them
Old Dec 11, 2011 | 10:55 PM
  #37
AARONHL's Avatar
Ah ok, paint just looks like it was done in areas. How did you make out with the radiator?
Old Dec 11, 2011 | 10:58 PM
  #38
mzenelji's Avatar
Its leaking, my friend found the leak at the bottom, when we took the whole front out, its not leaking alot, but its definitively emptying the coolant resrvior,
Old Dec 11, 2011 | 11:04 PM
  #39
AARONHL's Avatar
Have it re-sealed or buy a new one, your heat will be back in no time!
Old Dec 11, 2011 | 11:05 PM
  #40
mzenelji's Avatar
you think one of those radiator stop leaks that can be bought at any parts store would work??
Old Dec 11, 2011 | 11:07 PM
  #41
AARONHL's Avatar
I wouldn't use that as a permanent fix. Radiators are only like $100..
Old Dec 11, 2011 | 11:09 PM
  #42
mzenelji's Avatar
yeah your right, might as well spend the money and get it fixed permanently
Old Dec 14, 2011 | 02:24 PM
  #43
mzenelji's Avatar
Replaced the radiator still no heat, very little actually, and I found it a small hose by the heater core was leaking, I replaced it, and flushed the whole thing, and its nice and warm right now, my right headlight still has a problem its some electrical thing, before I put the bulb in there was electrical flow, once I conncted everything no electial flow to the regualr headlights, its dirving me crazy, while the other passenger headlight works fine
Old Dec 14, 2011 | 05:28 PM
  #44
AARONHL's Avatar
What does it say on the bottom of the headlight lens? OEM headlights? Wondering if the HID box could be faulty?
Old Dec 14, 2011 | 05:51 PM
  #45
mzenelji's Avatar
Original headlights
