Handling Problems
Old Dec 7, 2011 | 02:37 PM
Spilly's Avatar
Handling Problems
I tried searching around but I have yet to find anything.
I recently traded in my '09 Civic Si in on a '08 G35. I love the car and it's crazy how much more power it has. Just makes my civic feel like riding a moped.
I used to autocross my civic a good bit and I was pretty good. I even started getting the heel toe stuff down.
On to my question. On corner exit my civic would never get sideways when I applied the throttle. If anything it would push the front end. This was very easy to drive. This car, on the other hand, swings the back end way out if I give it too much gas.
Is there something wrong? How can I fix/change this? Thanks in advance for your help. Sorry if I'm being a noob...
Old Dec 7, 2011 | 02:39 PM
dooderek's Avatar
it sounds like you need more camber
Old Dec 7, 2011 | 02:43 PM
AzuMaster's Avatar
Its a rear wheel drive car. That's what happens. Your Honda was FWD. Completely diff animals. If you plan on tracking your car... practice. You went from 1 side of the bar to the polar opposite in just abt every way. Honda= Light, underpowered, FWD. G35= Heavy, powerful (to you for now), RWD. Good luck. Its not a steep learning curve but it will take effort to get it down.
Old Dec 7, 2011 | 02:46 PM
PAIXAO's Avatar
I suggest driving with the VDC on, especially if this is your first RWD
Old Dec 7, 2011 | 02:53 PM
5150DS's Avatar
Hmm, I don't remember there being an 09 G35. Maybe you mean a different year, or you bought a G37? Troll, maybe?
Old Dec 7, 2011 | 03:02 PM
Spilly's Avatar
Thanks for the advice so far. I'm not sure what camber is and I assume fwd rwd are abbreviations? Front weight distribution and rear weight distribution? Sorry I'm not very good with abbreviations.
Also @5150DS. I'm not sure why I put '09. It's a g35. Would have posted in the G37 section if I had a G37. Don't want to unorganize things. Guess I just put the same year for both cars.
Old Dec 7, 2011 | 03:11 PM
5150DS's Avatar
No biggee. If you have an 08, it is closer to the G37 than the G35 since it was the revised body and engine (same chassis as G37). I would post over there (V36 as opposed to V35) to get input from those guys as they might have a better understanding of your particular car. On this topic it is not so important, but on others they might be more help.
https://g35driver.com/forums/g35-sedan-v36-2007-08-217/
Old Dec 7, 2011 | 03:29 PM
AzuMaster's Avatar
FWD is Front Wheel Drive. RWD is Rear Wheel Drive. When you apply the throttle in a FWD the car is being pulled. When you do it in a RWD it is being pushed. So in your Honda stepping on the gas wld pull you out of the corner so the body of the car just followed the front wheels. That's y it was easy to drive. With the G you have to steer correctly and apply the right amount of pressure to the throttle so that thae car does not "step out" on you. Leave your VDC on at all times & remember to brake properly. Good luck
Old Dec 7, 2011 | 04:16 PM
Spilly's Avatar
Can I change my car to FWD?
Old Dec 7, 2011 | 04:20 PM
takeNotes's Avatar
^LOL really now?
Old Dec 7, 2011 | 04:35 PM
Spilly's Avatar
Originally Posted by takeNotes
^LOL really now?
Oh, is that a bad idea? Would I need different wheels? I noticed the ones in the front look different.
Old Dec 7, 2011 | 04:36 PM
AzuMaster's Avatar
LMAO. If thats the case, sell the G bro. Lots of decent FWD cars out there. Or go for AWD All Wheel Drive.
Old Dec 7, 2011 | 04:41 PM
AzuMaster's Avatar
Its a lot of mechanical work & thousands of dollars to do this. It can be done but its very expensive... you might as well buy a new car for what you wld be paying to convert to FWD.
Old Dec 7, 2011 | 05:22 PM
rvanderwerf's Avatar
Old Dec 7, 2011 | 05:29 PM
SDGenius's Avatar
troll for sure
