Condensation behind dashboard and clock?
Old Dec 13, 2011 | 11:20 AM
jdubin94's Avatar
Okay. I just bought an 05 G35 and there is a lot of condensation behind the dashboard and clock screen. I know it is behind. I have tried using windex. How can I fix this? Will i have to take it apart and wipe the screen clean from behind? Can someone please help me. It is very annoying and cleaning it will give my G a much nicer look. Thanks
Old Dec 13, 2011 | 12:10 PM
onevoice's Avatar
Can't you apply something hot on the other side or use a hair dryer until the condensation goes away?
Old Dec 13, 2011 | 12:29 PM
jdubin94's Avatar
How do I get to the other side??????
Old Dec 13, 2011 | 04:02 PM
bigjee's Avatar
He means blow a hair dryer while pointing it directly at the clock.
I guess its a free fix so try it out.
Heating the glass should cause the condensation to evaporate. Hopefully permanently.
Just hold the h.dryer at a safe distance in case you mess up the internal of the clock.
Old Dec 13, 2011 | 05:33 PM
bythabay's Avatar
you shouldn't use windex on plastics. Windex has amonia, which will damage plastics.
Old Dec 22, 2011 | 03:10 PM
Infiniti Chica's Avatar
It's a fairly open air system back there, behind the instrument panels, I can't imagine why you'd have condensation there unless you have water leakage from the outside that's hitting the heater core. This is just a wild guess.
Old Dec 22, 2011 | 03:36 PM
srv2nv's Avatar
G35 Sport
GF had condensation after she had her car detailed/cleaned. It eventually went away over the summer from sitting in the sun.
Old Dec 22, 2011 | 03:47 PM
5150DS's Avatar
I would be concerned that you car was flood damaged.
Tmatheso
Dec 13, 2015 03:24 PM
AesonVirus
17 Inch
Sep 20, 2015 02:05 PM
