upgrading fog lights/ front turn signals
Old Jan 2, 2012 | 08:36 PM
Carrottop401's Avatar
Originally Posted by 05_SkylineSedan
I like that yellow-ish HID fog idea but if I read those threads correctly, and as TunerMax says above, the single filament conversion will result in you losing your high-beams. (Only two wires from the ballast to the 3-pin plug...)
And since the "turn-indicator" on the '04 is a single filament bulb with no "markers", that would take a "single" type LED bulb if you end up going that route. The ones you pointed to say "no hyper-flash" so they may have the necessary resistors built in.
I dont really care about my high beams because my 6k hid's are bright enough for me...
And im still not sure whether to go the led route now because of the brightness factor!
Muski_G
Dec 1, 2023 11:11 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
Freddy07g35
Sep 17, 2015 08:53 PM
MT6002
Lighting
Jul 21, 2015 01:13 PM
attarday
Jul 15, 2015 04:03 PM
