Which OEM ROTORS are compatible with an 03 G35 Sedan?
Old Jan 18, 2012 | 11:52 PM
Skaterbasist's Avatar
Retired SuperMod
I understand the different set ups. But are they backward compatible with each other? I have a 2003 G35 Sedan.
In other words, can an 03-04 Coupe Non-Brembo rotor, 05-06 Sedan rotor, or 05-07 Coupe rotor fit on my 2003 G35 Sedan?
The differences between the 03-04 Sedan rotor vs the 03-04 Sedan Coupe rotors seem minimal. And the 05+ rotors are a bit more significant.
Thanks for the help!
Old Jan 19, 2012 | 05:43 AM
Blue Dream's Avatar
I drove ttrank's car solo
With the sedan you can't run 05-06 rotors up front from the coupe or the sedan as the calipers/rotors are smaller on your car. Infiniti made major improvements on the brakes starting with the 05 2wd versions, and carried that over to the X in 2006. Not sure about 03-04 coupe non-brembo though.
Old Jan 19, 2012 | 02:47 PM
SkyWay's Avatar
I have an 04 sedan and I bought Marcus's used 05 calipers and rotors. It was a direct swap and they work amazingly better than my stock ones. Best bet is to do the same if you want larger rotors
Old Jan 19, 2012 | 03:19 PM
Retired SuperMod
That's what I assumed for the 05+ rotors.
But, will 03-04 Coupe rotors still be compatible in my 03 Sedan? The differences are subtle as shown below... but I want to be 100% sure they are backward compatible with the 03-04 Sedan.
03-04 Sedan
Front: 11.7-inch X 0.9-inch power-assisted vented disc
Rear: 11.5-inch X 0.6-inch power-assisted vented disc
03-04 Coupe (Non-Brembo).
Front: 11.65-inch x 0.94-inch power-assisted vented disc
Rear: 11.5-inch x 0.63-inch power-assisted vented disc
I'm sticking with my OEM calipers. So my question still stands about other rotors working on the 1/1 piston configuration of the 03 sedan.
Old Jan 19, 2012 | 07:00 PM
Retired SuperMod
Anyone?
Old Jan 19, 2012 | 09:30 PM
AARONHL's Avatar
03-04 Sedan
I'd think that they are interchangeable since they are so close in dimensions.
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
