04 G35 Sedan, 350z springs only or springs & shocks replacement
Old Jan 26, 2012 | 02:49 PM
1arko23's Avatar
Question 04 G35 Sedan, 350z springs only or springs & shocks replacement
Hi
Im debating if I should buy the 350z springs or if I should go with springs & struts off of Nissan 350Z for my 2004 Infiniti G35 Sedan.
Can anyone help me out as to what the best and cheapest way to go is?
I want 1" drop.
Thanks
Old Jan 26, 2012 | 03:39 PM
RADIOGUY21's Avatar
I'd recommend changing everything. If you have the sport suspension, the unrevised 350Z springs are the same spring rate as our sport suspension, you can use your current shocks/struts if they have life left. I have 350Z front springs with unrevised G35 coupe rear springs on my sport shocks/struts. Setup is still good after 40K+ miles but I'll be due for new shocks/struts soon. Since you have an 04 you probably have some miles on them so its probably best to just swap everything, and go with the revised setup.
Old Jan 26, 2012 | 03:47 PM
G35xTurbo's Avatar
I have the same setup on mine and it looks aggressive and rides pretty close to stock. I'm going to go lower before long though.
R350k5
Oct 1, 2015 08:41 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
