Question(s) about dyno tuning
Old Mar 3, 2012 | 10:06 PM
Orbital1's Avatar
Originally Posted by ray1370
OP, back to the topic, FYI the topic of your thread is different from what you asked in it. To find out your gain with your bolt-on, you do a dyno run first to get your baseline before the mod; after the mods do another run on the same dyne to find out your gain. Different dynos read differently, as discussed previously, however what you need is the gain value. And then, to take full advantage of your mods, you get a tune, which most of us here recommend dyno tune on the same dyno. Then you'll see from baseline how much you really gain from all your mods. Just to clarify.
Oops, yeah, you're right. I just compared the title of the post to the content in it. I should of titled it, "Questions about dynoing in general". Sorry if that confused anyone.
Old Mar 4, 2012 | 12:10 PM
SkyWay's Avatar
Originally Posted by SE5spd
I have a VQ35
I have a 4.2 stroker
I have cams
I have heads
I have intake, exhaust, headers, tune.
I have retainers, springs, all valvetrain, I have 1000CC injectors and a A/M fuel pump
I haz E85
I haz 300.2WHP
Those are not basic bolt ons
Old Mar 4, 2012 | 12:23 PM
Shanes_G's Avatar
Originally Posted by SkyWay
Pretty sure there are more than a couple on my350z. I know there are some g coupes that have hit it as well. N/A is more than just bolt ons, you realize that right? You can stroke the engine and use high comp pistons to produce some really good results. There's a video on youtube of a g coupe that stroked his 3.5 to a 4.0 and is putting down 377hp and 347 ft/lb. That would be one hell of a ride!
Now if you were referring to 300 whp N/A on bolt ons, then yes, that is a lot harder to do.
https://g35driver.com/forums/tuner-d...-07-coupe.html
all i need is a light weight one piece drive shaft and i can break 300 easy.
Old Mar 4, 2012 | 02:21 PM
ray1370's Avatar
OP has a base AT btw.
Dyno runs cost about $80 for 4 to 5 runs, and if there's any local dyno event it might get cheaper, check the dyno section and local section for the shops around you.
Old Mar 5, 2012 | 01:11 AM
butkiss1's Avatar
I made 304 on a dyna-pac NA
The WHP numbers dont really mean much ,Its all about the traction
Old Mar 5, 2012 | 01:16 AM
butkiss1's Avatar
06 5AT
Engine/Drivetrain Modifications: 1. Aem cold air
2.3/8" MD Plenum Spacer
3.Grounding Gear 10 wire set
4.Stillen ceramic headers
5.Stillen engine damp
6.Motordyne ART Pipes
7.Stillen Generation 2 Cat back/with custom Xpipe & Muffler (Low Rasp)
8.Blox Throttle body spacer
9.Osirus
12.Rev limiter bumped from 6,750 to 7,400
13.Oil catch can
14.NGK Iridium
16. Magna Flow Resonated Xpipe
17. Magna Flow Resonated dual in /dual out Muffler
18. 100 octane performance map
19. Ported and sandblasted lower plenum
20. Ported and sandblasted lower runners
SE5spd's Avatar
304? when did you get redynod?
Old Mar 5, 2012 | 01:24 AM
butkiss1's Avatar
About 2 months after the dyno day when I did the ported and sand blasted lower runners..
jsimonk
Dec 22, 2023 03:49 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
sick_sixspeed
Jul 20, 2015 10:25 PM
