Wipers "catching" on intermittent
Old Mar 1, 2012 | 11:18 AM
g35x_KC's Avatar
Originally Posted by TunerMax
LMAO it's not the blades.
I have this problem too but I didn't realize it was common. Unless my issue is different, let me know if so.
I do know from what I've peeked briefly at thus far for my problem:
1. This issue happens when returning to the "park" position only. It will seem then, that any time it's on intermittent, it happens when they are returning to "park"
When in any other mode the wipers don't return to "park", they stay in "run" mode and dont drop down all the way. This is why you notice it in intermittent.
2. With the hood open and checking the linkages while the issue is present, it seems as I recal (checked B4 winter) that the issue is actually the motor mounting bushings being sloppy. This, or the motor itself is binding when returning to the "park" mode, and it's causing the bushings to shift hard due to the added stress.
I will be inspecting this further once I get some other stuff done on the car and I'll dig this post back up to show my findings.
If anyone actually knows the problem though (I still don't know what it is exactly), post it up please!
Agreed - NOT CAUSED BY THE BLADES!
Yes, it's when the blades return to the parked position, whether the end of a single sweep, the end of the washer cycle, or right before the pause between sweeps on intermittent. I will definitely go ahead and run them with the covers removed to see if I can narrow down the cause. It was doing it immediately after replacing the linkages, so I'm confident it's something else.
Old Mar 1, 2012 | 11:27 AM
01yellowr's Avatar
Check the link in post #11 for a fix. If that fix doesn't work then the problem is most likely the wiper motor that is going bad.
Old Mar 1, 2012 | 11:35 AM
g35x_KC's Avatar
Yep, thanks. I followed that thread when I replaced the links last year, so it's probably the motor itself that's causing the problem.
Old Mar 1, 2012 | 12:26 PM
AARONHL's Avatar
I saw in a thread that 03-04 wiper motors only work with 03-04, but what about putting a coupe wiper motor on a sedan?
Old Mar 1, 2012 | 03:31 PM
01yellowr's Avatar
I don't know if they are the same or not. But I hope they are. The coupe motors are going for around $50 on eBay and I can't find any for the sedan
Old Mar 1, 2012 | 03:57 PM
AARONHL's Avatar
Hahaha, I wasn't the only one who checked!
Old Mar 1, 2012 | 04:05 PM
01yellowr's Avatar
Lol. I thought I was the only one
Old Mar 14, 2012 | 12:34 AM
tdruk's Avatar
Ill have to try this when I take my car out of storage. The one thing that fixed it for me though was when I washed my car if I cleaned the wipers and waxed the windshield they worked like a charm. Didnt even need em in the rain since the water just beaded off from the wax
Old Mar 29, 2012 | 11:45 PM
texasg's Avatar
I changed out my links and I still have the issue im. I read another post about making sure to align them correctly with the lines on the windshield. im gonna try that to see if that will work
Old Mar 30, 2012 | 12:03 PM
01yellowr's Avatar
could be the wiper motor if the links didnt help
Old Apr 5, 2012 | 07:26 PM
texasg's Avatar
After I adjusted my wiper arms it hasnt had that slapping issue
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
vamarris
Sep 26, 2015 12:56 PM
douglas555
Sep 10, 2015 04:48 PM
mcneil_g35
Aug 5, 2015 12:03 PM
