Best parts to increase 0-60 times
Old Mar 7, 2012 | 09:41 PM
mike53187's Avatar
I'm sure weight is probably the biggest variable when addressing 0-60 times; however, was curious as to what other variables would have a fairly large impact on the 0-60 times as well. I have a 2004 g35x and mostly concerned with improving the times on this model.
Old Mar 7, 2012 | 10:07 PM
bran7761's Avatar
a lighter wheel/tire combo will be very noticeable.
rotating mass is the enemy.
Old Mar 7, 2012 | 10:11 PM
mike53187's Avatar
anybody have any specific stats/metrics?
Old Mar 7, 2012 | 11:02 PM
VQ35 revv's Avatar
I was gonna say slicks but you got a AWD....
Bolt-ons will help a bit. If you want to spend more money, than a TT setup or supercharger.
If you wana keep it cheap you can strip your interior haha. But to do that on a G is a sin IMO
Old Mar 7, 2012 | 11:12 PM
5150DS's Avatar
Ls1.
Old Mar 7, 2012 | 11:15 PM
bran7761's Avatar
Originally Posted by 5150DS
Ls1.
thats never been done..
Old Mar 7, 2012 | 11:35 PM
dominate's Avatar
Well you have an AWD (wouldn't for 0-60 times the AWD be faster than the RWD?)
Old Mar 8, 2012 | 09:59 AM
pulsar1's Avatar
Why would you want to increase 0-60 times?? I'd want them lowered myself. Heavy rims will increase it for sure though, maybe a smaller exhaust?
Old Mar 8, 2012 | 10:02 AM
ccc123pm's Avatar
X
Power to Weight ratio, increase power or reduce the unsprung weight. Also, transgo valvebody upgrade for snappier shifts
Old Mar 8, 2012 | 11:55 AM
artsVQ's Avatar
plenum spacer
pulleys
intake
full exhaust
y-pipe
test pipes
headers
cams
grounding kit
transgo shift kit
upgrade gear in the rear diff
and a good ECU TUNE by uprev
you can always go supercharger or turbo kit
Old Mar 8, 2012 | 12:40 PM
g35x_KC's Avatar
Old Mar 8, 2012 | 02:49 PM
5150DS's Avatar
Then he can be the first.
Old Mar 8, 2012 | 03:29 PM
DKano's Avatar
^^ What's never been done?
https://g35driver.com/forums/picture...nuff-said.html
Anyways, you can change your gears. That might hurt your top end though and might hurt gas mileage (the RPMs will be a little higher when cruising).
Old Mar 8, 2012 | 03:37 PM
SDGenius's Avatar
^never been done w/AWD
Old Mar 8, 2012 | 05:45 PM
snowtrax's Avatar
There really are no great ways to increase your 0-60 times other than the obvious (turbo or blower). I would either get a chip to make it feel more responsive or a grounding kit would also better the driving experience.
