Headlight bulb change help!
Old Jan 6, 2005 | 12:15 PM
EverybodyWildOu's Avatar
Hey guys. Does anyone know how to change the headlight bulb on a non HID G35 sedan? Cause I took a look under there and there is nooooo space to work. Someone help me out please!
Old Jan 6, 2005 | 12:25 PM
dklau33's Avatar
Look in your owners manual. It will have a section on DIY stuff which should include changing the headlight bulbs. It's easiest if you remove the two front wheels for maximum space. Then you have to remove the fender well plastic covering. These should be held on by a couple of screws and plastic clips. After you get the plastic cover off you should be able to see the two plastic caps that cover the lowbeam bulb and the high beam/foglight bulb. Good luck. And avoid touching the bublbs with your direct hand.
Old Jan 7, 2005 | 11:40 AM
cato's Avatar
SouthernComfort Moderator
I changed all the bulbs in my non-HID sedan. I bought the Sylvania SilverStars for
both the fog and low beams. Did a seach here on G35driver.com and found exact
instruction on how to do it. I even found pictures of the install job.
I did not need to remove the wheels. The search function works pretty well!
Old Jan 7, 2005 | 12:42 PM
G35Lin's Avatar
Multi-Spoked Mod
hm..... remove the bumper?? then you can take the headlights out and replace the bulbs?? i did that!
Ed
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
itztwinki3
Lights
Oct 15, 2015 04:38 AM
as25656800
Aug 9, 2015 07:25 AM
EasySausage
Jul 20, 2015 03:56 PM
attarday
Jul 15, 2015 04:03 PM
