best wheels
best wheels
I just bought a 2004 G35 about 3wks ago now im looking to mod ...1st thing i wanna do is get 19in deep dish rims maybe black with chrome lip or silver machined finish after the wheels i wanna replace my stock bose system with the pioneer AVH_P4400BH double din..what other mods do my fellow g35 driver think woukd look amazing for my ride.
^ did you just contradict yourself?
"Agree with wheels then drop" - so wheels first, then drop
"No drop with wheel is no good" - drop first, then wheels
"any drop with some wheels is better" - drop first, then wheels
Everyone has suggested a drop so far, so I'm going to go out on a limb and help with narrowing down some suggestions.
First, OP, how much are you willing to drop on wheels, as well as tires for them? Your budget can open up a ton of options, or can narrow them down to just a couple companies. New, authentic/high quality sets run upwards of $4k, used on the forums ~$2k-3.2k. Replicas, new can be at or a little above a grand, used aren't that much cheaper.
OP should really consider the coupe 19s route. There is a XXR wheel that has the black/chrome lip look you want. Depending on your city or near by cities, searching 'infiniti' on craigs list will eventually bring up a set with or w/o tires for under $1000. If the OP had $3000 to spend on wheels, he probably woulda picked up a newer model G instead. I agree with most of the others stating a drop should be the first mod, but those 17s should be changed soon after. The other typical first mods of a K&N, Z-tube, Spacer, Y-back or Cat-back exhaust. Anyway, good luck with the searching and modding. Post your progress for feedback from the community.
So im guessing a drop is a must which i totally agree but what is the difference between springs and coilover.Is one more expensive than the other..I seen a set of Eibach springs the Pro-kit or Sportline..I dont want my car slammed just enough of a drop so theres no gaps..I dont like the black lining all along the bottom either what would be a good kits nothing to expensive.
