New struts and springs
Apr 6, 2012 | 02:49 PM
Ok guys so it's that time to replace my struts . I am looking to buy th topiko for 312 on eBay . Or 546 for both eibach pro kit and the struts. I this a good deal or do you think one of our vendors have better prices?
Reply 0
Apr 6, 2012 | 04:01 PM
Buy the tokiko shocks on ebay and get tein s tech springs for 170$ shipped. Thats $482 total. 64$ cheaper than going with the Eibach setup
Reply 0
Apr 6, 2012 | 10:13 PM
Just remember, if you drop much more than an inch you will be running alot of camber. This will wear the inner part of your tires, unless you get adjustable arms.
Reply 0
Apr 7, 2012 | 12:52 PM
Ok cool . The pro kit drops it 1 inch exactly . You think I will need camber or I can't get away with the toe ? And of course alignment
Reply 0
Apr 7, 2012 | 01:10 PM
Ok guys so order the topiko struts and the eibach pro kit. Which is 1.1 drop all around. I'm concerned about the tire wear. Will cambrr or toe kit be needed if so please show me some link and the price range. Thanks
Reply 0
Apr 7, 2012 | 01:56 PM
If you're just going with an inch drop why didn't you just go with the z/g drop? Probably couldve found the springs for about $150 at the most and then you could've just bought the shocks/struts and saved money. It may have even given you a better looking drop and evened out the car more.
As for adding a camber kit I doubt you'll need it but if you lower it more in the future I'd definitely get one but you can probably get away without it at only an inch lower.
Reply 0
Apr 7, 2012 | 02:51 PM
Yeah I think even think of that , your right I probably could of but i kinda wanted it right now , instead of looking lol what set up are you on?
Ok cool I was trying to see I absoultely needed it. Everyone know tires are expensive lol
Reply 0
Apr 7, 2012 | 03:03 PM
I would seriously consider buying from a vendor or even seeing if a local shop can match or get close to those prices, ebay can be a nightmare and you never really know what you're getting...
Reply 0
Apr 7, 2012 | 03:04 PM
Quote: Ok cool . The pro kit drops it 1 inch exactly . You think I will need camber or I can't get away with the toe ? And of course alignment
I would highly recommend a rear camber kit, no front tho. They're not that expensive, you can pick up a camber/toe kit for like $150
Reply 0
Apr 9, 2012 | 02:04 AM
What you mean? Thats the set I went with
Reply 0
Apr 9, 2012 | 03:35 AM
For a 1" drop, 350Z (revised) springs are pretty much what you will need.
Reply 0
Apr 9, 2012 | 11:56 AM
I ended up going the more expensive way for the 1 inch drop with the pro kit. But your right I shoulda went with the z revised springs. I'll post pictures once I install. A lot of times I don't see too many twlight sedans on here
Reply 0
