Problem = -$ :(
Old Apr 13, 2012 | 04:17 PM
SSJRICH's Avatar
Problem = -$ :(
I hate when crap goes wrong. So I have had this problem in the rear end. Initially I thought it was bearing related... Of course it was, but the actual (hmm I dont know what its called) the part that the wheel studs are attached to. probably the hub. anywho it was ground down probably 1mm and therefore was causing the bearing to fail. So now not only do I have new rear bearings, but a new passenger side hub....
Oh and about a grand less.... If I had more time, I would have done it myself. I am a pure DIY'er but I just have zero time right now, and its a couple day job as you have to get the bearings pressed etc... I hate paying for labour.... Grrrrr
Old Apr 13, 2012 | 04:32 PM
G35Papa's Avatar
Sorry to hear for your problem. At least it's all fixed now and you can enjoy the car again
Old Apr 13, 2012 | 04:35 PM
onevoice's Avatar
Should not be a grand to replace just the bearing and hub
Bearing $50
Hub $125
To get them pressed ~$20
Labor $100-200
Under $400 at max IMO
Old Apr 24, 2012 | 09:36 PM
SSJRICH's Avatar
Yea I wish....
I did both rear end bearings and the hub was $400
I know I could have done this job myself to save the labour (about $400) But like I said, I had no time and needed it done then...
Old Apr 25, 2012 | 02:09 AM
AARONHL's Avatar
Doesn't take long, yank the bearing/hub out at night and have someone press it the next morning. Finish the job that day before work..
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
