8in Sub install??
8in Sub install??
So i've been thinking of installing an 8in sub in the spot where the bose one would be in if i had the bose system. I just need a little bass not a lot tho, but i haven't installed an aftermarket deck. Any way to hook up the amp and sub to the stock deck?
trying searching couldn't find anything
Thanks
Luis.
Thanks
Luis.
I drove ttrank's car solo
Received 1,487 Likes
on
Wrathernaut (04-22-2012)
What size sub is that? I have a 15 in my truck and the smallest box possible and it takes up most of the trunk. How expensive are you talking for that enclosure?
on
Boxology only makes a box for the sedan that houses a 12" sub. They're $315 w/o a grill plus shipping. Here's the link. http://mysosinc.com/box_inf_gsedans_G35.html
on
on
I'm in the process of a DIY 8 sub in the rear deck. i did have a sub in it, but it fits too close to the rear seats. So, there is no room for a box. i cut out a little of the rear deck (left the spot welds) and built a sealed box for my RF punch 8. i get no rattles. have all my room left and have some nice bass. I had to cut the carpet piece that covers in the trunk a little. but i can still put in the baby strollers, go shopping and all. I can post some pics in the morning.
If you plan on putting a sub in the rear deck, realize that in order for it to properly be set up, you need to seal up the front waves from the back waves. If you look up what an infinite baffle setup is, that's exactly what you're doing. Also realize that whatever the sub's power handling is, you now need only half the power since you're using the trunk as your enclosure (one huge box). Also, make sure to use some sound deadener. I'd recommend some liquid deadener and possibly even some foam like material used for sound deadening.
In all honesty, it's a lot of work. What I'd recommend is going with a single or dual 8's, maybe a single 10, one that doesn't require much volume for the enclosure, and have a box made that takes shape to the rear seats to maximize space. You really won't need a powerful amp and there's plenty of small footprint amps that are out there. If you need something that packs a lot of power and still need a small footprint, the Alpine PDX amps are one choice to consider.
There are plenty of subs to go with, just go on a car audio forum like caraudio.com or caraudioclassifieds.org and search. Ask around as well and you'll find plenty of useful information. There's a bunch of subs people don't know about just because they're not mainstream and sold in big chain stores. Don't get me wrong, companies like JL Audio make great drivers, but I've owned a lot of subs, I'm talking over 50, and I've had a few 10's and 12's that get louder than a 13w7 and with less power, not to mention, sound much better. It's all in the driver, not the size.
I know this may come off as being a little conservative, but I have had alot of success supplementing the factory head units in my last 3 cars with an Infinity Basslink.
In my 2004 sedan with the non-Bose setup, it mounts neatly up into the left corner of the trunk, and when tuned correctly, is very complimentary to the factory unit.
In addition, most people that see it in the trunk think its a factory upgrade.
http://www.amazon.com/Infinity-Bassl.../dp/B000063TJY
I have an extra epicenter at home for that, but it is just way too much trunk space to put my kickers in. I know there are plenty of options for small subs. But just the combo amp/sub looked like a good deal. Except after reading the reviews, it looks like the majority of those combos just blow up after a year or less of use.
Interested in pics
