Just how bad is the 6 speed tranny?
Old Jan 10, 2005 | 08:13 PM
G35_TX's Avatar
If I had to do it again, I would get the 05 with the updated tranny. I wouldn't touch a older one. My 04 had a 2nd gear problem since it was new, and then 6th gear went out later. Had it replaced, then had issues with 3rd gear 2 weeks later acting up. So I got rid of the car for a Titan for now till I buy a extra toy car.
Old Jan 10, 2005 | 08:14 PM
dbarnes's Avatar
Hey "G Spotter":
I've read where Infiniti has refused to replace/repair (and even voided transmission aspect of warranty) the 6MT for using non-Nissan fluid - I'm sure it was on this site, even.
I have grinding into 6th gear when shifted quickly (meaning normally) there from any other gear (3rd, 4th, 5th), it's only smooth if I pause slightly when shifting - Don't know about a redline shift from 5th yet
It also grinds (crunches, actually) under full throttle/high RPM shifts from 1st to 2nd (freeway onramp merging, pulling out into heavy commute traffic, showing the kid in the Integra GSR a thing or two - wait, did I say that?), and I'm going to bring it up when I go in for my 15,000 mile service within 30 days. With that in mind, and since I first started encountering the problem(s) (at about 7,500 miles), I've inquired and paid attention to others problems both here and on Fresh Alloy (including the coupes and the "Z"), and the changing of the oil issue arose.
I wholeheartedly concur that changing to Redline will smooth things out - it has done so on several foreign and domestic cars I've owned through the years (a great cure for "slow synchros), but I would hate to lose my warranty for something this minor.
Maybe I'm wrong - but proceed with caution.
My $0.02
Old Jan 10, 2005 | 08:41 PM
Gsedan35's Avatar
Originally Posted by RacerX
Sorry for the stupid statement....I don't know where my mind was.
Don't worry no one's perfect, I'm certainly not.
Old Jan 10, 2005 | 09:58 PM
BamaMT6's Avatar
just turned 20000 miles on the odo today - no problems with the 6MT, even when shifted quickly.
Auto vs. Stick is a debate that will run on forever (or until all the mfg take them away from us.....an M5 with an auto only, what is this world coming to??)
You need to make the choice based on your own preference and driving habits. Is the 6MT great on a winding country road?? you bet! Does the 6MT suck bigtime in rush hour traffic?? again, a resounding yes
The remaining factory warranty is for your peace of mind - 4 yrs, 60K mikes should provide many worry free miles.
My old TL-S dropped an auto at less than 10K miles, but they fixed it with little fanfare and provided a loaner for the duration - Infiniti should do nothing less
Old Jan 10, 2005 | 10:46 PM
G35_TX's Avatar
Originally Posted by gspotter
I have an '04 Coupe 6MT (July '04 build). It has only 2400 miles on it so far. I've just replaced the manual transmission fluid with Redline MT-90 because it is a new car and I wanted to get any metal shavings out. It shifts super slick and I've never grinded any gears yet. It's not notchy at all and the shifter barely vibrates at all. I've heard that there has been something like 6-7 updates to the transmission so far, and with a July build I suppose my transmission is probably one of the latest updates. I'm super-impressed with it thus far. It is beyond my expectations. Be sure to test drive the vehicle you are interested in, and if you purchase it, go ahead and change the transmission fluid if it never has been changed before. Good luck with whatever you decide.
I did this on mine right away, and truthfully it made my 1-2nd gear grind worse. I put the factory fluid back in and it actually got better fo rthe next 15k of miles. Glad I did because warranty would have not covered the repair.
Old Jan 10, 2005 | 10:55 PM
gspotter's Avatar
I'm not so sure this is a good idea. I have used Redline for years in cars with great results. But you really do not want to give Infiniti a chance to blame a transmission failure on using other than the official Infiniti fluid. I have heard horror stories like this, where it is used as an excuse to deny warantee coverage. I had my trans, and rear axle fluid changed at 25k, but I paid through the nose to have the dealer do it just to cover my a**. As soon as the warantee is up, I wouldn't hesitate to use Redline.
I knew someone would post this reply. Thanks for your concern! I expect the transmission will run longer and smoother with less wear with the Redline fluid. The way my transmission is working, I don't expect any failures during the warranty period. I know that's saying a lot at only 2400 miles, but it really does feel perfect. I'll let you know if it ever goes kaput. I don't drive my car that all-out and hard compared to a lot of other owners. I've talked to several mechanics that work on Nissan/Infinitis about this very issue and I decided to go with the Redline. What each owner does depends on what they feel comfortable with. Meanwhile, I'll enjoy the super-slick shifting which is a joy as of now.
Old Jan 10, 2005 | 10:58 PM
gspotter's Avatar
If it starts grinding, I'll switch back. The car has never grinded and it shifts super-slick. I can't imagine the '05's shifting any smoother, of course I hope to try one out sometime.
Old Jan 11, 2005 | 12:58 AM
DaveB's Avatar
Too late, I bought an 03 sedan automagic tonight. I'm very happy. The tranny is what I wanted. I'm just tired of rowing the gears now. It's fun and then it's not. I'm sure the auto will be the same way. I also like the fact that the G auto rides behind the 5.6 V8 Titan and Q45/M45 V8s. That means the 5-speed auto rated to handle a lot more than the stock 3.5 can dish out. My project 90-93 notchback 5.0 Mustang will have a manual though.
Old Jan 11, 2005 | 03:19 AM
kysrsoze's Avatar
Originally Posted by DaveB
I'm just a little resistent to buying a 6 speed because the 6 speeds seem to have syncro problems with these trannies. Just how common are the 6 speed problems? It's my understanding that Nissan has had multiple updates to the 6 speed tranny.
I bought an '04 and have had zero problems with it. I hammer it hard at times. I believe all the isses have been resolved. Guess the 6th tranny update must have done it. I haven't heard of any '04' + cars having manual transmissions problems.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
Cskeet
Jul 21, 2015 05:48 PM
