Headlight won't work
Old May 7, 2012 | 03:56 AM
jclinton_s's Avatar
Have 2004 g35 sedan. Headlight went out replaced it with a Xenon HID, worked for about a day and then stopped working, Put in another bulb and it does not work. Checked fuse and it's ok, Any suggestions or help on what the problem could be?
Old May 7, 2012 | 09:27 AM
acr's Avatar
acr
Does the high/fog work? Maybe your ballast went.
Old May 7, 2012 | 09:28 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sounds like your ballast went bad. You might want to swap ballasts from side to side to see if that's the issue, but if it is you can usually find them on ebay for under $100. My dealer wanted over $500 for a new one bastards.
Here's one for less than $60 shipped. http://www.ebay.com/itm/INFINITI-Xen...aa5ab2&vxp=mtr
Old May 7, 2012 | 10:46 AM
TunerMax's Avatar
G35
x3 on ballast
Old May 8, 2012 | 11:36 PM
jclinton_s's Avatar
fog lights works no problem, haven't tried high beam. Stupid question what is the ballast?
Old May 9, 2012 | 01:06 AM
TunerMax's Avatar
G35
The ballast runs the HID, which is your main headlights (top one).
HID stands for High Intensity Discharge
This type of bulb actually has a high voltage arc that creates the light you see, but to acheive such a high voltage arc, you need a transformer. Not much different than what you see on your telephone/hydro poles, the big drum/cylinder unit.
This changes High Voltage to High Amperage. Well the one in your car does the opposite, it changes High Amperage to High Voltage to run the Bulb.
You didn't really need to know that, but there you are.
All you need to know, is it's a box that looks something along these lines, has 3 screws holding it, and will be mounted to your Headlight IIRC.
Junkyard is your best bet, or you can order a cheap knock-off online. If you're going to spend money and get a good one, I suggest taking the one off the other side and testing it on the side that isn't working before you invest any money.
Old May 12, 2012 | 03:41 PM
jclinton_s's Avatar
I'm guessing to install a new ballast the easiest way is to remove the whole headlight to gain easy access or is there another way to do this or do you have a link with DIY instructions on how to replace? Thks again for all your help.
Old May 12, 2012 | 04:24 PM
5150DS's Avatar
Ballasts with bulbs
http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
Old May 12, 2012 | 08:31 PM
TunerMax's Avatar
G35
You will need to remove at least part of the inner splash guard around the wheel to access the headlight mounting. At this point, you might be able to change the ballast without removing the headlight. I haven't done one on the G yet, but I think it's possible to change it once you get the splash guard out of the way.
Old May 19, 2012 | 01:14 PM
jclinton_s's Avatar
Any idea where the ballast would be located? I guess just follow the wires located on the bulb plug that should go directly to the ballast.
Old May 19, 2012 | 02:40 PM
Blue Dream's Avatar
Jack up your car, remove your underpanel, and look under your light; you'll find the ballast. I can't remember if you need to take out your inner fender liners to get to it. In this pic it's part #11.
Show more
Old May 19, 2012 | 10:54 PM
StrongG35x's Avatar
Yeah, ballast replacement was really not too bad. Turn the tire all the way to the inside, jack up your front end, pull plastic clips *carefully* (broke one while removing mine), remove inner fender splash guard, remove old ballast, plug and screw in new ballast, put splash guard back on, and bask in the glory of saving yourself a couple hundred dollars. I replaced mine this past fall- took about 30 minutes. If I did it again, would probably take 15. They do have some good writeups on here if you want to see some pictures.
Old May 20, 2012 | 12:42 PM
jclinton_s's Avatar
thanks everyone for your help and posts. Will work on this next weekend. One last thing any idea the best place on the web to buy an inexpensive ballast?
Old May 20, 2012 | 02:58 PM
5150DS's Avatar
Look at post #8, read your thread.
Old May 20, 2012 | 10:41 PM
jclinton_s's Avatar
One last thing on the HID bulbs are they suppose to get really hot. When I installed the new bulb within 60 seconds of turning it on it got really hot and I accidentally touched it and it burnt me slightly.
