Horn Issues
Old May 13, 2012 | 10:26 PM
Kingd's Avatar
Horn Issues
So i have an 03 sedan and today i was playing around with the FOB, i pressed the panic button and everything worked. I decided to go into the car and check something out and i left the lights on and it made that constant beep sound; i turned it off and got out my car to lock it. Usually when i lock it the hazard lights blink a couple time and the horn goes off, however this time the car's horn didnt go off. I tried putting it back on and off from hazard + horn and silent hazard.
My question is, is it coincident that my horn stopped working or was it because of me messing around and i somehow disable the horn? If the horn is busted anyone have a clue where i can order a new horn? Thanks in advance
Old May 14, 2012 | 07:45 AM
5150DS's Avatar
You can disable the horn sounding when you arm the alarm.through the remote. I am not sure how you do it. To see if you horn is broken, reach in your car and push the center of your steering wheel. If your horn honks then it is not broken.
Old May 14, 2012 | 10:31 AM
Kingd's Avatar
yeah i did switch the horn using the FOB key and the horn on the steering wheel stopped working. Im just seeing maybe i missed something before i go out and buy a used/new horn. Its just weird how i was messing around with it last night and now it stopped working.
Old May 14, 2012 | 01:32 PM
GraphiteGSdn's Avatar
There is a low and hi tone horn so it is unlikely that both would have busted. I would check to see if the fuse tripped.
Old May 14, 2012 | 02:24 PM
mrwgottaG35's Avatar
hold lock and unlock at the same time for 3 seconds, horn should come back on for locking with the fob if its not in-op
Old May 14, 2012 | 02:42 PM
Kingd's Avatar
So my horn did not make low or hi tone at all; this is true, its unlikely that both horn are busted at the same time. After looking further into the car, the problem was the fuse, it never occurred to me that it could be the fuse. Thanks for your help
Old May 14, 2012 | 02:45 PM
Kingd's Avatar
Yep, i tried that last night and it never beep, thanks for the suggestion. GraphiteGSdn helped me figured out the problem, it was the fuse that went bad.
Old May 14, 2012 | 02:47 PM
Kingd's Avatar
Thanks for all the help everyone, horn is working again and i am relieved; btw this cost me 5 dollars, cheap, and simple problem!
Old May 14, 2012 | 03:04 PM
NjMatteSedan's Avatar
Car's horny again!
Old May 14, 2012 | 10:31 PM
Kingd's Avatar
haha shes good to go
Old May 26, 2012 | 10:42 PM
Kingd's Avatar
OK this is ridiculous! So i mentioned a few weeks ago that my horn stopped working and i brought it into a shop and they found out the fuse was no good, so the fuse got replaced. After work today, i arrived home and went to lock the car, there was no horn! Would you guys know why my horn fuse keep going bad?
cmesidewayz
Sep 29, 2015 09:28 PM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
PZ06G
Interior
Aug 24, 2015 06:27 PM
Rehman2009
Jul 27, 2015 03:23 AM
