Oil in spark plug cylinder.
#46
I just changed my plugs with 160K on the odometer. #6 was full of oil. Dealer quoted me $800 to RTV the plug seals. It has run fine for 10 years and 160K miles. I think I will just keep on driving her as is and save the $800 for the used G37 convertible I want next.
#48
#52
I had oil in #6 as well, but have driven 30k mi since my plug change. Doesn't seem to affect anything.
#54
#55
I'm in Charlotte, but if you're down this way check out CIN Motorsports. They will replace your covers with Maxima covers for $95 each, and about $130 in labor. That is a savings of $480. I am having mine done this week.
#56
When your there please get the part number for the Maxi covers. I was under the impression that they wouldn't fit the G.
#57
#59
Sure, tell them Evan sent you. Just to be more specific, I was getting some work done on my car already, and I'm not sure if the labor price reflects that or not. Either way, you will save a lot of money over buying the stock covers.
#60
![Question](https://g35driver.com/forums/images/icons/icon5.gif)
I do not know the proper numbering of the plugs. I only got a chance to remove all of the driver side plugs before I lost sunlight.
The attached pictures are of my three driver side plugs. The middle plug and the left plug were soaked in oil. Before replacing, should I be cleaning the plug tubes? What is the proper way to do so?
95k miles
95k miles
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
