Custom Exhaust Setup Question? 06 Sedan Catback
Old Jun 19, 2012 | 06:34 PM
Paper73's Avatar
Currently I'm running a full stock catback sedan on my 06 G35.
My question is:
What would be my best route to take if I plan on getting the Motordyne ART resonated pipes? As far as Y-pipe, mid-pipe, muffler, etc.. (headers?)
So to word this a little better.. I want to put on the ART Pipes, but I also want to do everything else exhaust related while I'm down there.. What would be the best combination of parts for maximum power output without an insane drone or annoying HKS sound (sorry if that offends anyone, I don't like the sound :P)
I definitely want a deeper sound and some light drone is always sexy, just nothing that's gunna have cops on my *** haha.
I was originally looking at the full Borla Catback system swap, but I figured it wasn't the most power oriented route.. So any suggestions would be awesome.
And also, as far as piping goes, would 3 inch piping be too much right now for a car that isn't heavily modded? I'm eventually going to be taking her 600+, but I'm not sure if I should stick with 2.25/2.5 until I'm a bit closer to that.
Thanks guys! Any help is greatly appreciated!
Old Jun 20, 2012 | 01:44 AM
dineth00i30's Avatar
If you are going to boost then I would save some money and get 3" piping now.
Old Jun 21, 2012 | 10:19 AM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Originally Posted by Hydrazine (Motordyne)
Back pressure (at least on our engine) is NEVER a good thing for NA applications.
It is a widely spread myth that some back pressure is good, but it is 100% FALSE.
There clearly are situations where smaller diameter pipes can outperform larger diameter pipes but this is not because of back pressure. This is because of scavenging. And when tuned properly, scavenging actually reduces back pressure as seen by the engine.
But be careful in the assumption that smaller automatically equals better performance. It is highly dependent on where the smaller diameter pipes are being used.
Small pipes near the engine can be good for scavenging and power, but as the pipes move farther and farther away from the engine the effect of scavenging rapidly diminishes. If scavenging cannot be taken advantage of, then small/restrictive pipes must be completely avoided.
Back pressure can only reduce power. Do not confuse this with scavenging.
Scavenging actually reduces back pressure on a tuned cyclical basis.
With each pulse released during the exhaust stroke of the engine, the pulse travels like a shotgun blast down the exhaust pipes. The high intensity blast creates a shockwave with a large positive pressure at the wave front. This wave front is traveling so fast that even when the piston reaches TDC and all the gas is expelled by the piston, the fast moving slug of exhaust gas doesn't stop and it rarefies the gas and creates a vacuum behind the shockwave.
It is the vacuum behind the shockwave that sucks out any remaining exhaust gas from the cylinder. This vacuum also pulls more fuel/air mixture through the intake valves during the intake/exhaust valve overlap period. And this is how more power is made. This is the scavenging effect. It vacuums exhaust gas out of your engine!:thumbup:
Adding back pressure can only kill off this vacuum that you want.
NOW HERE IS HOW THE MYTH STARTED.
IT WAS A MISINTERPRETATION OF TEST RESULTS.
Sombody a long time ago probably did the same series of dyno tests I did on varying pipe diameters. Like I did, they probably found that smaller diameter pipes can yeild higher HP and TQ. They probably mistook this for back pressure and put it out in the public. Smaller diameter pipes can provide higher performance when used properly. But small diameter pipes are only desirable when they are very close to the engine.
For example:
I did a series of dyno tests on various diameter test pipes ranging from 2.5", 2.25" and 2.0".
Before conducting the tests, my initial guess was that the larger diameter pipes would produce the highest HP with lowest TQ. And the smaller diameter pipes would produce the lowest HP and the highest TQ.
Well... I was 1/2 right...
As expected, the dyno testing showed the 2.5" diameter test pipes made the lowest TQ. And as expected, the dyno testing showed the 2.0" diameter test pipes made the highest TQ.
But here's the kicker. The 2.0" test pipes made 2 more HP than the 2.5" test pipes! ...It left me thinking "COOL.:thumbup: Smaller diameter test pipes make more TQ and more HP. That's a wining combination!"
So sombody a long time ago probably misinterpreted the smaller diameter as adding performance by being more restrictive. But this is not the case. It is because of increased scavenging. Smaller diameter pipes near the engine increase the velocity of the shockwave and thereby increasing the effect of scavenging. It was a misinterpretation of the results.
So I continued down this line of testing at the Y-pipe primaries. Using the 2.0" test pipes, I then tested various Y-pipe primary diameters. 2.0", 2.25" and 2.5".
The expectation was to see similar results... but not quite this time. At least not at the Y-pipe.
The 2.0" Y-pipe primaries did indeed provide the highest TQ, but it brought a good portion of the HP down. 2.25" primaries were better but could still be improved upon. The 2.5" Y-pipe primaries provided the best peak power and the best average power.
So dyno testing proved the best test pipe diameter is 2.0" diameter and the best Y-pipe primary diameter is 2.5".
I then continued further down this line of testing on the mid-pipe and made some more interesting observations. Testing mid-pipe diameters at 2.5", 3.0" and then a fully open Y-pipe.
What I did find was that there was no scavenging effect possible after the Y-pipe. There was nothing to gain from the smaller diameter what so ever. In fact, the only thing that had any effect was simple back pressure.
Using a open Y-pipe as the baseline I found that connecting a 3" single exhaust had no effect on TQ and with only a small 1.5 HP decrease.
The 2.5" midpipe slightly reduced TQ and was ~2.5HP down from than the 3" midpipe.
This series of tests established:
1) There was no scavenging possible after the Y-pipe.
2) A smaller diameter midpipe can only decrease HP&TQ
3) There will be rapidly diminishing returns beyond a 3" midpipe
4) With power to weight ratios taken into consideration a 3" midpipe can be considered optimum. 3" also allows more headroom for medium boost FI applications.
Going from 3" to a 3.5" midpipe may at best provide a 0.5HP increase. So from a weight point of view, going larger than 3.0" would be counter productive for NA applications.
I then conducted another series of tests at the end of the Y-pipe.
1) Attaching a 3" diameter butterfly valve with variable position restriction plate.
2) Attaching a 6" diameter parabolic diffuser to reduces pressure drop below that of a 3" open pipe.
The purpose of the butterfly valve restriction plate was to directly test the effect of raw back pressure on performance. And the results were very clear.
BACK PRESSURE RAPIDLY REDUCES PERFORMANCE.
I dyno tested the valve at various levels of flow restriction. From wide open to almost fully closed as back pressure was increased, performance rapidly decreased.
This set of dyno plots is proof positive that back pressure is the enemy of power and torque.
Let the myth of back pressure be permanently dispelled from the vocabulary of this forum!
After that series of tests I started another set of tests that decreased exhaust pressure beyond that of a simple open ended 3" pipe.
A 6" diameter parabolic diffuser was clamped onto the end of the Y-pipe. This was used to decrease flow resistance below that of a open pipe.
Dyno tests of the diffuser showed an instant 4-6HP increase over that of a open Y-pipe!:thumbup:
This picture below is a picture of a 5" linear diffuser. It doesn't perform quite as good as the 6" parabolic diffuser but the 6" diffuser is completely impractical for fitment and production reasons.
6" is too big for fitment under the Z and the parabolic shape also gives it a curvature that makes the production process MUCH more difficult.
This is the diffuser used on the MD ShockWave single exhaust system. It can also be attached directly to the Y-pipe for drag race applications.
So while there are rapidly diminishing returns with going to larger and larger diameter tubing after the Y-pipe, significant gains can still be made by use of diffusers.
The back to back dyno testing shown below was a simple open Y-pipe as the baseline and then with the diffuser attached.
Old Jun 21, 2012 | 10:21 AM
re-crue13's Avatar
https://g35driver.com/forums/g35-sed...ust-sedan.html
Old Jun 21, 2012 | 05:14 PM
spoonierme's Avatar
if your planning on going big power, take my advice and plan ahead. if 600whp is your goal, your going to need to go FI, and if you do that, get it done right and go with a 3inch piping exhaust. It may reduce performance for you right now, but later on you'll get more gain.
Old Jun 22, 2012 | 10:09 AM
Mrpatar's Avatar
So for n/a applications he says 2 inch test pipes with 2.5 inch y pipe and 3 inch exhaust?
Old Jun 22, 2012 | 11:32 AM
re-crue13's Avatar
Thats exactly what he says, 2" test pipes, 2.5" primaries for the Y-pipe into a 3" collector, then 3" Y-back.
Old Jun 22, 2012 | 11:26 PM
TunerMax's Avatar
G35
3" exhaust will not hurt your power. If you're boosting in the 600+ range you'll want considerably bigger than that with tuned headers.
Anything smaller than 3" is a complete waste of time on this car, don't even consider it. Even if you plan to keep the rest bone stock.
Old Jun 26, 2012 | 09:41 PM
Paper73's Avatar
Sorry I haven't been replying guys, had some personal problems come up.
THANKS EVERYONE for all the replies, I really appreciate it! Really gave me some things to think about. I'm a little sad because I thought I had everything figured out... Guess not
So would Motordyne ART Resonated TP's not be a good idea? They're only 2.5" right?
Or would they be fine, so long as I go 3" for the Y-pipe, etc?
Hopefully I can still snag an answer from someone - I know it's been a few days.
Thanks again guys! You're awesome!
Old Jun 28, 2012 | 08:07 PM
TunerMax's Avatar
G35
There's a lot more to this than just size.
Here's the straight forward good setup for a stock or lightly modded car:
Y pipe is a waste of money. Unless yours is rotten don't bother with it.
ART pipes are a great mod but expensive, and can effect your emmisions if you have to do regular inspections.
If you can afford them, and it's not a huge inconvenience to you for emissions testing, then get them. They're one of the best exhaust mods you can do.
The rest of the exhaust after that Should be 3". Mandrel bent. It will be louder, expect that.
The muffler is a measure of your taste, no one can tell you what to get, and online sound clips aren't very helpful.
Expect that any aftermarket muffler will be quite a bit louder than stock.
FYI notes: Y pipe and ART pipes NEED TO BE SMALLER than the rest of the exhaust. This is done to INCREASE performance. Tuning is essential to optimize these parts. ART pipes are a tuned/tested product you can depend on for a wide range of engine modifications from stock to light boost. And even on boost they're still better than any other test pipe/cat on the market.
Y pipes are pretty well designed right from the factory. There's not really any difference getting an aftermarket one except minor changes in noise. Again, not worth doing.
Old Jun 30, 2012 | 06:04 AM
NjMatteSedan's Avatar
Get an HR Y pipe
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
