Popcharger = AC Problem?
Old Jun 20, 2012 | 01:30 PM
supG35x's Avatar
Ever since i got my JWT popcharger installed, my AC is gone.
I recharged it twice within 2 months and i still HOT air when the ac is on.
today's weather is hitting 100degrees in MASS
Anyways, please let me know how i can fix this problem b/c i dont want to pay $200 to fix it.
Thanks!
Old Jun 20, 2012 | 01:59 PM
dofu's Avatar
20 Year Member
I don't know how else to explain it, but there is basically a switch or valve on your ac up front that needs to be toggled or opened. If you had the PopCharger installed at a shop, they might have closed it before they installed the intake.
Old Jun 20, 2012 | 02:09 PM
supG35x's Avatar
I actually installed it myself, is it possible that i couldve closed it?....
Old Jun 20, 2012 | 02:16 PM
dofu's Avatar
20 Year Member
It doesn't hurt to have someone check it if you don't know how to. It's definitely cheaper than replacing parts.
Old Jun 20, 2012 | 03:06 PM
TunerMax's Avatar
G35
Guesses:
You bumped or moved the wiring/plug for the A/C pressure switch. This will cause the system to read no pressure in the system and it won't turn on.
Check the Switch itself and the wiring to it/plug, etc.
Old Jun 20, 2012 | 03:13 PM
TunerMax's Avatar
G35
Hrm... edit to that.
The switch isn't really close to the intake at all.
Old Jun 20, 2012 | 03:17 PM
TunerMax's Avatar
G35
Anyways there's a diagnostic procedure you can use with the Automatic Climate Control.
http://www.nicoclub.com/FSM/G35/Sedan/2004/atc.pdf
Start on Page #38 for the troubleshooting and component locations.
Actual Self-Diagnostic procedure I mentioned starts on Page #52
Old Jun 20, 2012 | 03:31 PM
Mr. Brett's Avatar
Were you forceful when you installed your pop charger? The only possibility I can think of is that you may have damaged your AC lines during the install, or cracked the hard line somehow so that you have a pinhole leak somewhere.
Does your AC blow cold immediately after a recharge?
Old Jun 20, 2012 | 04:04 PM
G35Papa's Avatar
A couple of things.
The Pop-Charger has a known issue of hitting the AC line that runs down the inner fender wall. Most people put foam or a piece of rubber hose (thats what I did when I had the charger a long while back). Check to make sure you didn't puncture the line.
Second, did you by any chance do any work under the dash/steering column that day? There is a sensor/plug behind the panel under the ignition, if its unplugged, it will blow hot air. There is actually a tube that connects to this sensor.
Hopefully it's something simple. Good luck
Old Jun 20, 2012 | 05:41 PM
supG35x's Avatar
Yes ac blow cold immediately after a recharge.... it will run ac for a week and then it will blow hot air again.
Old Jun 20, 2012 | 09:40 PM
TunerMax's Avatar
G35
Sounds like a leak to me. Time to get the leak check out.
Old Jun 21, 2012 | 03:23 AM
Mr. Brett's Avatar
^ This.
Get a reputable shop to do a dye test. They should be able to fix it in no time flat.
Old Jun 21, 2012 | 09:13 AM
supG35x's Avatar
Originally Posted by TunerMax
Guesses:
No leaks what so ever. The has full charge (probably overcharge b/c i recharged it twice.)
Anyways, where could the switch be? I must have turned it off.
Old Jun 21, 2012 | 09:32 AM
gambit2083's Avatar
First, of all save this to you cpu: you will thank me later http://www.nicoclub.com/FSM/
Second, your climate control has a SELF-DIAGNOSTIC MODE that you can perform to help you with your ac system instead of guessing. It helpded me figure out that it was my compressor in my g and the fan control amp in my wifes maxima and the blower moter on my pathfinder. I would taking the laptop to the car and scroll as you go through the checks.
start on page 53, your welcome
Old Jun 21, 2012 | 09:53 AM
TunerMax's Avatar
G35
How do you know there's no leaks?
did you do the diagnostics I showed you already? that's free, do it. Post results.
WOW man you're a godsend!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!
If only some one would have posted this earlier!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
Oh.... wait.
