What is a transfer case?
Old Aug 26, 2012 | 06:19 PM
Mide's Avatar
So I'm looking into getting the rest of the fluid work done that the previous owner did not do on a 30k maintenance run.
I understand there there are many different fluids that could be swapped like the:
Brake, Coolant, ATF, Rear Diff, Front Diff.
But while looking around the forums I saw that someone mentioned "transfer case fluid"
I'm not sure what this is...is it another name for the area where the ATF is held or is it a completely different component? Sorry if it's a dumb question...tried to Google it but found conflicting info.
Old Aug 26, 2012 | 06:28 PM
Swivel's Avatar
Moderator
A transfer case is a part of a four-wheel-drive system found in four-wheel-drive and all-wheel-drive vehicles. The transfer case is connected to the transmission and also to the front and rear axles by means of drive shafts. It 'transfers' power to both differentials.
The fluids recommended by Amsoil (for example) are:
Transfer Case,......AF3 [4]
Synthetic Multi-Vehicle Automatic Transmission Fluid (ATFQT)
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Old Aug 26, 2012 | 07:14 PM
StratagemII's Avatar
https://g35driver.com/forums/g35-sed...se-fluids.html
Old Aug 26, 2012 | 08:04 PM
Mide's Avatar
Got it, thanks. So how often are you guys changing the front, rear, and transfer case? They are listed as 30k under the premium schedule. Is this just right or too often?
Old Aug 27, 2012 | 05:17 AM
5150DS's Avatar
Do you have a g35x? If not you do not have a transfer case.
Old Aug 27, 2012 | 10:37 AM
Mide's Avatar
Yup got a G35x
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
f22raptor
Mar 18, 2016 08:50 AM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
