Tried out my Harrison RD OBDII software on my G35 tonight
I don't know if it's old news or not on this Org according to the "search" function, but I was able to use my Harrison RD OBDII on my G35. The Harrison RD software allows you to record, view, and graph engine parameters in real time while driving. It simply plugs into your OBDII connector and then your laptop. You can view things like engine temp, rpm, ignition advance, air flow, O2 sensor voltage, MPG, fuel trim, etc. plus you can read and clear CELs. I'm going to use it to log air flow and ignition advance with 95 octane, Z-pipe, and some other things. I want to watch the advance during part throttle in 1st and 2nd gears with the auto because once you hit 3rd, it's as if the motor all of a sudden wakes up without any additional throttle application.
Not a bad little toy for $120. Here are pics of it in my old Maxima:
Originally Posted by MightyG35
Cool thanks. So it should work on any OBDII system right?
I got the scanner mostly for my wife's 98 Legacy GT because there is no way to pull the codes or clear them without going to the dealer and paying $90. This scanner has already paid for itself plus I do my own work which saves me even more.
And for those wondering, this is not an engine management device. It strictly is a reader, not a tuner.
Originally Posted by ChicagoX
How is the datalogging? Length? Resolution? Thx.
I have had the AutoTap OBD2 interface tool for a while now. ODBScan sounds like a similar tool. I bought the Autotap after my wife left the gas cap off of our minivan. Ford charged $130 to tell us the gas cap was loose. I will never bring my car in for service with the SES light on without knowing what the cause/codes are. AutoTap came in handy with my G when I changed the air filter. I accidentally started the car with the Mass Airflow Sensor disconnected. Reconnecting the MAS and doing an ECU reset didn't fix the SES light. AutoTap took care of it. OBD scan readers are worth every penny spent IMHO.
Bump...
Sorry for the newbish questions, but does this thing work for the G? I want some datalogging... something cheap and this looks pretty good. Which one in that link is it?
http://www.ghg.net/dharrison/obdscan.html
The one pictured is the Harrison unit. He's got new software out plus USB capability now for much quicker datalogging.
Dave, I borrowed my old Alex Pepper OBDII scanner. I'm going to hook it up to the G just to see if there are codes. I suspect none though. One thing I've found is that Nissan cars aren't as friendly to this software. As in less things I can fool with. Maybe it will be better when I finally get the Auterra (non-CAN version)
Is there any way to reliably read the knock sensor, or is this not even part of the OBDII spec?
Are you worried you're seeing knock?
[QUOTE=DaveB]I don't know if it's old news or not on this Org according to the "search" function, but I was able to use my Harrison RD OBDII on my G35. The Harrison RD software allows you to record, view, and graph engine parameters in real time while driving. It simply plugs into your OBDII connector and then your laptop. You can view things like engine temp, rpm, ignition advance, air flow, O2 sensor voltage, MPG, fuel trim, etc. plus you can read and clear CELs. I'm going to use it to log air flow and ignition advance with 95 octane, Z-pipe, and some other things. I want to watch the advance during part throttle in 1st and 2nd gears with the auto because once you hit 3rd, it's as if the motor all of a sudden wakes up without any additional throttle application.
[QUOTE]
Will this toy work for just about any car w/ an OBDII? Maybe I can talk the wife into buying this since her 528i's(2000) "Engine Service Light" is on. If I can reset it w/ this tool, it'll pretty much pay for itself because I know the dealer or service shop will charge me a lot more. And of course I can use it for my G.
[QUOTE]
