Pumping Gas
Old Oct 22, 2012 | 10:07 PM
texasg's Avatar
Angry Pumping Gas
Hey guess I have done a search and came up with nothing. has any1 else had an issue when trying to pump gas and the gas handle stops pumping gas. I can start pumping gas for just a few seconds and the pump shuts off like if the car is full. Its not the issue that people have tring to fill up. Im having an issue just pumping gas period. This happens every time i try to pump gas doesnt matter if the car is on empty 1/2 full doesnt matter.
Old Oct 22, 2012 | 10:57 PM
Texasscout's Avatar
If I remember correctly, this was an issue in first gen cars. I think there was a TSB / recall on it.
Old Oct 22, 2012 | 11:04 PM
5150DS's Avatar
+ 1
Old Oct 22, 2012 | 11:07 PM
Roh's Avatar
Roh
yah i have the same problem... just started happening. i usually just pull out the pump a little further and keep filling the gas tank up.
if ther was a recall on it, can i still get it fixed? if it just started happening?
Old Oct 22, 2012 | 11:29 PM
19kdrill's Avatar
Service bulletin ITB08-041a "Hard to Fill Fuel Tank"
You'll need part #'s 17366-EY80A (cut bracket) and 17342-01A00 (o-ring). Think it was around $10-$15 for everything.
Hope that helps!
rob.g
Old Oct 23, 2012 | 12:54 AM
5150DS's Avatar
I don't think they will fox it unless it is under warranty. They might do a good faith repair if you are the original owner. However that is up to the dealer.
Old Oct 23, 2012 | 06:29 AM
ArkansasG35COUPE's Avatar
I use the "pull out" method for most my fill up's.. No pun intended!
Old Oct 23, 2012 | 09:46 AM
texasg's Avatar
im gonna have try that and see if it works.
Old Oct 23, 2012 | 10:50 AM
infinitig35's Avatar
I also had that happen to my car. I'll go to a different gas station than that problem goes away.
Old Oct 23, 2012 | 12:45 PM
Texasscout's Avatar
I have to do that with my 2011 Frontier also. I just barely "put it in".
Old Oct 30, 2012 | 08:18 AM
texasg's Avatar
So i tried the "pull out" method and i can actually hear the gas sound like it is getting blocked or stuck down the next of the tank.
Old Oct 30, 2012 | 08:55 AM
albundy1987's Avatar
I have had that problem on my 2006 G35x. It only happens every now and again. I will try "pulling out" when it happens in the future. Thanks!
Old Oct 30, 2012 | 01:54 PM
bizz518's Avatar
I haven't had this problem with my 06 g. I DO have this problem with my 07 jeep hemi though.
Old Oct 30, 2012 | 04:55 PM
GR6RR's Avatar
gas gauge weirdness is what you might be needing to search for...
Old Oct 30, 2012 | 10:11 PM
d0nutboii's Avatar
Ive had this issue, but it only seemed to happen at a specific Shell location that i went to...
