cup holder lid sticking
Old Nov 5, 2012 | 11:18 AM
sandaluv's Avatar
hi. my center console cup holder is sticking and when it finally releases it opens very slow. anyone dealing with this? what could be causing this and is there a fix w/out replacing the whole center console? btw 05 sedan AT. thnx guys
Old Nov 5, 2012 | 11:44 AM
5150DS's Avatar
Mine did the same because I spilled a sugary beverage I in it. I put hot water in the cup holder and let it sit. This freed it up most of the way, then usage did the rest.
Old Nov 5, 2012 | 01:43 PM
ArkansasG35COUPE's Avatar
Contact Tuner Clearner on the slides/hinges... Worked for me after Monster Energy drink spill..
Old Nov 5, 2012 | 05:09 PM
VMRWheels's Avatar
Hot water will probably do the trick if it's from a sugary drink. I still need to get around figuring out how to work on mine as well.
Old Nov 5, 2012 | 05:12 PM
05 sedan's Avatar
i have the same problem. is there a DIY on how to remove the center console? I have search but I only get 03-04
Old Nov 5, 2012 | 10:10 PM
sandaluv's Avatar
Thumbs up
thnx for the replies guys. after messing with it for a while it started working properly. it really sounds like what u guys are saying (spilled soda). how hard is it to remove the console?
Old Nov 5, 2012 | 11:00 PM
DBML912's Avatar
https://g35driver.com/forums/audio-v...h-removal.html
Follow SOME of the steps in this thread. Then the rest will be easy. I had the same problem. I took mine apart last year, took out the buttons for the heated seats. Soaked it in warm water and scrubbed the little mechanism with a wet paper towel to get what was caked on.. off. Blow dried it with compressed air and put everything back together
Old Nov 5, 2012 | 11:06 PM
DBML912's Avatar
Hope that'll help you guys out
Old Nov 6, 2012 | 01:45 AM
sandaluv's Avatar
Thumbs up
thnx dbml. this was helpful indeed. tomorrow i will do this along with swapping coupe mid pipe
Old Nov 6, 2012 | 02:25 PM
VMRWheels's Avatar
Thanks!
Old Nov 6, 2012 | 11:00 PM
DBML912's Avatar
No problem. When i did mine. I just went at it, wish i ran into that thread before hand. It would of made it go by somewhat faster.
I hate the cup holders though. Lets everything slide back, forth and tips the drink
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
mbe32
Nov 13, 2015 11:09 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
