Anyone done wheel bearings....twice?
Dec 11, 2012 | 05:02 PM
Quote: Running a 2004 AWD Sedan 130k and noticed the hum about 5000 miles ago. No noise when cornering, or taking an expressway on/off ramp but it’s been progressively getting louder. As the noise got more pronounced I realized that it is definitely the front end, but is still very difficult to determine the side. I figured a bad bearing must be producing heat resulting from the excess friction. I drive about 60 miles to and from work a day. When I got home on two separate occasions, I laid on my back next to the wheels , reached in and checked the all four axles as close to the spindle as possible. If your fingers are skinny enough you can get even closer to the center of the shaft where it meets the spindle but mostly I just wrapped my hand around toothed area. I assume that is the end of the CV joint. It’s around 30-40 degrees outside and three of the points were cold. (Probably at air temperature) The passenger front was warm to the touch. I would say a 25 to 35 degree difference in temperature. I feel pretty confident that it’s the passenger front bearing that is going bad. This will be a DIY for me in the next week or so. I just bought the car, less than a year ago so this is the first bearing change for me.
I would suggest using caution with this method as I don’t know how hot this area could get with a really bad bearing.
Hope this helps someone.
I would suggest that you do both sides. When one side of the bearing is gone, the other one will follow shortly.
Reply 0
Dec 12, 2012 | 08:05 PM
Thanks for the feedback all.
I'm at 95K on my 04 Coupe. I get the humming over about 40. Sounds like I know what's happening before I get new wheels.
Reply 0
Dec 15, 2012 | 07:51 PM
Just had mine done at 83k. Stock 2005 G35x. Same symptoms as others loud hum/whine above 40mph coming from front of car, thought it was tires at first but found this thread and sure enough...replace the bearings and all is good feels great and much quieter.
Reply 0
