Door Light Switch Not Working
Old Dec 17, 2012 | 09:17 PM
neo_anderson302's Avatar
After installing a LED that blew a fuse, I'm having a problem with the dome light that I installed that bulb in.
I replaced the fuse.
Installed a different bulb.
Issue is the push button in the light won't switch the bulb on or it just blinks for .5sec., but doesn't stay on like the other side. It works when set to door, but if I push the lens the light will go out. On the working side the bulb stays on when you push the lens.
Any thought?
Old Dec 17, 2012 | 10:04 PM
anyone?
Old Dec 18, 2012 | 06:38 AM
Blue Dream's Avatar
I drove ttrank's car solo
LEDs are polarity specific so pull the bulb, reverse it, and re-install. See if that helps.
mike730
Jan 12, 2018 04:25 PM
wonderizm
Sep 24, 2015 03:09 AM
apintojr
Jul 23, 2015 10:52 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
