Cold Startup *squeak*squeak*squeak*squeak* - Belt noise?
Old Dec 19, 2012 | 12:06 PM
achillesg's Avatar
I've searched and not sure if the sound I'm hearing is described or not:
Some mornings (not all) i hear a brief (.5-1 sec) squeak that repeats for anywhere between 2 and 10 seconds (*squeak*squeak*squeak*squeak*...), then goes away with what I think might be a fan kicking on.
This morning pulling out of the garage with my window down, I heard the oscillating squeak again when turning the wheel all the way to one side. This made me think power steering belt, but why would that squeak on startup?
Thanks guys!
Old Dec 19, 2012 | 03:34 PM
Subiedrewbie's Avatar
Could be a pulley.... How's the belt condition? They are pretty easy to swap if they r in bad shape
Old Dec 19, 2012 | 04:23 PM
Mustang5L5's Avatar
Tighten up the belt *just* a tad.
Old Dec 19, 2012 | 08:19 PM
5150DS's Avatar
Is your ac/defroster on when this happens?
Old Dec 20, 2012 | 01:32 AM
kpowe1's Avatar
Check the condition of your belts, if the belts are in good condition just tighten. If your belts, still make the noise then try some belt dressing.
Old Dec 20, 2012 | 01:09 PM
CROYCE992's Avatar
I'm definitely thinking it's your timing belt. You can visually inspect it and see if it has deteriorated at all.
Old Dec 20, 2012 | 02:43 PM
I think you mean drive belts... We having timing chains
Old Dec 21, 2012 | 11:35 AM
g35indafuture's Avatar
I'm having similar issues, but mine started this week around the time the weather dropped (socal)...let me know how it turns out.
Old Dec 21, 2012 | 12:39 PM
That's G's Avatar
I would say it's got to be your drive belts slipping. I had this problem as well and after I replaced them, the squeaking stopped. You can always tighten them a little bit if the belts are in good condition still.
Been frost on my car when I walk out in the morning in SoCal also. Got cold all of a sudden.
Old Jan 8, 2013 | 11:52 AM
achillesg's Avatar
No sir...
Old Jan 8, 2013 | 12:01 PM
achillesg's Avatar
Will do. I hope there's a good DIY for the belt tensioning somewhere, such a noob!!
Old Jan 15, 2013 | 06:39 PM
achillesg's Avatar
So I sprayed some WD40 on the belts and the squeaking was INSANE for about 10 miles oh hwy driving, then finally went away. I tightened up the small belt pulley and tensioner, and now for the first few minutes the car is on, the sound is alittle different than a squeak, almost a squeal or a swivelling type noise. Its intermittent when the car is idling now also. Help!
I was planning on swapping both drivebelts and possibly both pulleys if they have slop/resistance, good plan?
Old Jan 15, 2013 | 06:49 PM
Stryde's Avatar
Why did you put a lubricant on the belts? Go figure!
Old Jan 15, 2013 | 10:04 PM
achillesg's Avatar
Yeah thanks. Made perfect sense after it made all that noise!
Any thoughts on the plan? Someone at work said they thought it sounded like a water pump bearing gone bad. Last thing I want is for this to lead to overheating issues.
Old Jan 15, 2013 | 10:36 PM
gary c's Avatar
Belts squeak when they get old and frayed especially in cold weather, kinda like the poly bushing on my Vette. There's no doubt they need replacing but you can keep them quiet temporally by rubbing a bar of soap on them....this is an old school temp fix. I recommend buying OE belts from Nissan, there quality is far better than what the local auto parts store sells....Gary
