Slip while turning left
So, here's a completely stupid question. I have an 2006 G35x. With the slightest bit of moisture on the ground, I run the risk of slipping when the wheels are turned to the left. Forward or reverse, fast, slow... whatever. What might cause this? I've checked the pressure and the tread, but they're both find. Alignment's ok as well. Any help would be appreciated.
If your alignment is correct, the issue is likely tires! What is the UTQG on the tires you're running? To get all the traction you need anything over 600 could be causing your issue. My Michelin PS2s are 240 so I can damn near climb walls.
Best mileage and traction the UTQG should be close to 300....Gary
Best mileage and traction the UTQG should be close to 300....GaryRegistered User
Best mileage and traction the UTQG should be close to 300....GaryTrending Topics
