I am getting code P0304 which is a Cylinder 4 Misfire on my 2005 G35 Sedan
I replaced all the spark plugs, replaced the coil on cylinder 4, and the car went back to normal. It was shaking pretty bad especially when you gave it gas. After the replacing the above mentioned parts the car drove fine for 1 night, this morning as i was getting to work it started going in and out of the shakiness. Finally i get to work, and it was full blown shaking again, and the P0304 code is back. Does any one have any helpful advice on this issue?? Please Help.
First thing, did you change the correct cylinder?
Bank 1 = passenger side = cylinders 1, 3, 5
Bank 2 = driver side = cylinders 2, 4, 6
A little troubleshooting would be to switch the coil to another cylinder and see if the code follows the problem. If not, make sure the spark plug is not fouling due to oil and such.
It could be a failing fuel injector as well.
tehmoonrulz
Jul 19, 2015 10:44 PM
