Aluminum pedals
Old Jan 25, 2005 | 06:06 PM
Grotman's Avatar
Aluminum pedals
I like the aluminum pedals and was thinking about putting them on my '05 6MT Sedan. I was under the impression they were coming on it from the factory, but it looks like they only ended being on the coupe.
My questions are:
- Will the '04 pedal kits fit on the '05? I see Grubbs has a set.
- What is the real 'advantage' of aluminum pedals. I like them because they look cool.
- Is there a negative other than them likely being a little more slippery?
Thanks in advance for any insight.
G
05 6MT Sedan Graphite/Graphite
Premium Package/Aero/XM
Old Jan 25, 2005 | 07:24 PM
BbyG35's Avatar
The pedal are aluminum with raised rubber "nubs" so they are in fact less slippery. The gas pedal however is more slippery since it is simply a drilled piece of aluminum with no rubber nubs -- but that's less important since no real pressure is applied during normal driving, contrary to braking.
I have them on my 2003.5 sedan and would assume they'll fit a 2005.
Anyone else like to chime in with info on install on 2005??
Old Jan 25, 2005 | 10:19 PM
G35Papa's Avatar
The aluminum pedals add 45hp when put on a stock G I know, I know...not funny.
They should fit..........post a pic of your 05 pedals so we can see if there is any difference in the setup.
Old Jan 25, 2005 | 11:55 PM
aam6906's Avatar
should b the same
Old Jan 26, 2005 | 11:39 AM
cato's Avatar
SouthernComfort Moderator
My questions are:
G
I have them on my 2003 Sedan. Besides looking great, they are NOT slippery at all.
(At least the ones from Grubbs) I had a loner last week without them. My God, those
factory pedals are so Fugly! I don't know why anyone would not upgrade to the drilled
aluminum pedals.
Old Jan 26, 2005 | 02:01 PM
wnpublic's Avatar
They will fit the 2005 6mt sedan. I just put them on last night.
It's not hard, just took a little more elbow grease than I thought. Only the gas pedal was a little scary - hard to see down there, and i kept worrying about breaking the little clip that you need to saw off it. All went fine, however.
One tip - get a short flathead screwdriver. You'll need it to ease the rubber lip over the clutch and brake pedals.
Old Jan 26, 2005 | 02:20 PM
DINOONE's Avatar
Same thing here got them off ebay perfect fit...
alessandro
Oct 8, 2015 09:29 AM
AL8782
Oct 3, 2015 10:26 AM
blnewt
Sep 25, 2015 01:48 PM
Blindside360
Sep 18, 2015 09:00 PM
