2006 G35 Sedan Midpipe Question...
Old Feb 11, 2013 | 11:13 PM
Mike_WN6's Avatar
Hey y'all, got a 06 Sedan.
Anyway, read multiple threads and still got one question I'm a little confused on. I do want to tweek the exhaust a lil bit based on reviews, sounds, and youtube clips.
For my sedan, I do plan on getting HKS axleback plus a midpipe from a coupe like what others said.
My question is, what year (or years) would I need to get a midpipe from a G35 coupe so it can fit with the y pipe and then from the hks axleback when that comes in...?
Like I said with the clips I have seen, I do want to go with that setup. Just need to figure out which years of the G35 coupe (if it matters) I can get the midpipe from. Thanks
Mike
Old Feb 11, 2013 | 11:19 PM
Swivel's Avatar
Moderator
As long as it's off a V35 I think you're good to go, so 03-07 (?). If I were you, though, I'd try the HKS with your current middy first -- it's pretty small and the HKS is straight through so you'll get quite a sound bump even without the coupe middy. It's the setup I currently run and IMO was not much different with the coupe middy (which can be hard to find).
Old Feb 12, 2013 | 08:03 AM
Blue Dream's Avatar
I drove ttrank's car solo
Mike
Be prepared for some drone with the HKS. I ran it for a while with multiple combinations of y pipes and mid pipes and couldn't get the drone to go away. Finally sold it and got a Motordyne exhaust.
Posted from G35driver.com App for Android
Old Feb 12, 2013 | 03:58 PM
jhaddad112's Avatar
Any g35 coupe midpipe will fit(2003-2007). You should also look at the HR Y-pipes, those are also a direct fit from a g37, HR 350z, 370z, and HR g35.
Old Feb 13, 2013 | 09:38 PM
Airic214's Avatar
you have any sound clips?
Old Feb 14, 2013 | 09:20 AM
Peoria35sedan's Avatar
Seriously? Have you seen this thread https://g35driver.com/forums/g35-sed...mpilation.html It's only 6 years old, stickied and what you what to hear is on the first page, my god!
Old Feb 14, 2013 | 09:45 AM
MikeDG's Avatar
FYI, if you get a midpipe from a Z you will need about an 8" extention for it to bolt up. The Z mids are shorter than the Gs.
arora_g35
Apr 16, 2026 02:52 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
R350k5
Oct 1, 2015 08:41 PM
BlackGee35
Jul 23, 2015 01:36 PM
ResoG35Sedan
Jul 14, 2015 10:30 AM
