my belt tnesioner pulley bracket gone bad !?
Old Mar 7, 2013 | 10:20 PM
68_GT's Avatar
I was planning to change out my belts and noticed one of my tensioners like this one is screwed up
http://www.ebay.com/itm/06-Infiniti-...f2251f&vxp=mtr
where the head of the long screw meet the bracket at that fork at the bottom the bracket apparently has bent up and the head of the bolt has chewd it up some. When I try to tighten, or loosen the tensioner pulley the head of the long bolt just pops out, or chews up the bracket even more. It's a weak piece of metal, I guess the pevious owner messed it up. Has anyone else had this problem ? Is there something better to replace it with, or should I just get another OEM replacement bracket.
Any tricks to replace it, or pretty straightforward ?
Old Mar 8, 2013 | 09:53 PM
AARONHL's Avatar
Easy, just costs more than you think ahahaha, even the new one appears to be the wrong size and you will be tightening it a lot. Wish it was designed differently
Old Mar 10, 2013 | 11:04 PM
68_GT's Avatar
Maybe I'll pull it off and try to weld it up better / stronger....
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Moskvitch
Sep 14, 2015 10:15 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
