NEED HELP! Strange noise
Dont know if this has been discussed on here before (saw something a few weeks ago about a knocking noise but sounds different) but after turning on the engine, warming it up and going into drive (<5mph) after coming out of reverse, I hear what sounds like something being engaged in the engine compartment
. It happens everytime where I hear a hard knock followed by a series of low clicks (5 to 6 clicks) and it only happens when I come out of reverse and slightly push down on the gas. Does anyone have any ideas about where the noise might be coming from. Its an 04 with only 2400 miles on it.
Also interested as to when the other sedan owners in here got their first oil change (mileage) just so I know when I should schedule one (also have them check the noise problem).
. It happens everytime where I hear a hard knock followed by a series of low clicks (5 to 6 clicks) and it only happens when I come out of reverse and slightly push down on the gas. Does anyone have any ideas about where the noise might be coming from. Its an 04 with only 2400 miles on it.Also interested as to when the other sedan owners in here got their first oil change (mileage) just so I know when I should schedule one (also have them check the noise problem).
is your car a x by any chance, becasue if it is the sound would be the allwheel drive system engaging because i dont think its on in reverse.
i got my first oil change at 4500 miles.
Originally Posted by Xman
It's probably the ABS system check.
I am familiar with the awd noises but not that.
Xman, you say it does it regular when you are just taking off, and it is some sort of ABS system check?
Wayne
Originally Posted by GEE35X
I will have to listen for this I have never noticed any noise like that from the ABS except if it kicks in when stopping on ice the odd time.
Wayne
Wayne
Originally Posted by ABQ_G35
Yes, that is what he is referring to, it's almost like a slight air brake type sound.
Wayne
Okay, thanks for the reply I will listen for it, and also check my manual tomorrow.
Wayne
Wayne
When I hear mine it sounds like it's coming from about the base of the steering wheel.
The insulation may be better in newer G's now, so hearing it may be more difficult. (either that or your hearing aid is off--
Originally Posted by gsedanman
Wayne, on my Coupe, and as I remember on my Sedan, that ABS self test noise happened only once per day for me after initial cold start up and after engaging the transmission, just as you reach 3 or 4 kph (in forward or reverse).
Tomorrow when I take my better half to work, I will shut down the tunes on start-up, and we will both listen for this.
What did you say? I can't hear you. Thanks Colin , hehe, whats this stuff about hearing aids, There are more senior members around than me.
RATS.... I forgot
to listen for this abs noise this morning at start-up.
I realized I probably have not heard it yet cause it has been so darn cold since we got the G (Dec.7th) and the heating system and fans are always going full blast first thing at start-up. So my hearing is OK.
Oh, and ABQ_35 I just turned 56 years young a couple of weaks ago.
Wayne
to listen for this abs noise this morning at start-up. I realized I probably have not heard it yet cause it has been so darn cold since we got the G (Dec.7th) and the heating system and fans are always going full blast first thing at start-up. So my hearing is OK.
Wayne
I can only speculate to the noise since my G has yet to arrive...and it's killinG me. Any how while I've been waitinG I have down loaded the owners manual...here is what it has to say about the ABS system and its self diaGnostic test that it performs at low speed. If you happen to have your foot on the brake pedal while self test is occuring you will probably feel some feed back through the brake pedal.
Normal operation
Self-test feature
The anti-lock brake system consists of
electronic sensors,electric pumps,and
hydraulic solenoids controlled by a com-
puter.The computer has a built-in diag-
nostic feature that tests the system each
time you start the engine and move the
vehicle at a low speed in forward or re-
verse.When the self-test occurs,you may
hear a clunk noise and/or feel a pulsation
in the brake pedal.This is normal and is
not an indication of any malfunction.
Normal operation
Self-test feature
RATS.... I forgot
Wayne
Wayne
RATS.... I forgot
Wayne
Wayne
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
I fear your problem is not the ABS system checking itself ,but I'm more inclined to think it's the actuator on the auto5 not making the smooth transition from reverse to drive without ratcheting slightly. NOT TO WORRY ...If I'm not mistaken it's a computer activated adjustment that the dealer can do in minutes (after he confirms that I'm right and not smoking crack). Even if it's done via linkage...still a quick fix. So turn that frown upside down Sparky
JBX
JBX
