Exhaust Corrosion 2004x Sedan
Old Apr 25, 2013 | 09:51 AM
FireGuy385's Avatar
Hey guys,
I noticed this am that there was a rattling coming from the rear of my 04X. I hopped back there and noticed that the muffler was loose, as in I can push it with my hand and it moves pretty freely.
I have read the other exhaust threads, but don't know the actual pas that are affected/ need replacing so the "y-bar" and "midshaft" don't mean much.
I am hoping you guys can look at these pics, and let me know what I have and what I need to replace. From there I'll do the research as to what I like best/can afford.
Thanks in advance.
Old Apr 25, 2013 | 10:30 AM
04G35NYC's Avatar
Its a common problem, these exhausts are complete garbage.
Old Apr 25, 2013 | 10:34 AM
ccc123pm's Avatar
X
muffler flange looks like its gone. The midpipe flange looks to be intact. need to muffler.
Old Apr 25, 2013 | 11:41 AM
Plur's Avatar
I have a coupe midpipe + y pipe if you need them.
Old Apr 25, 2013 | 11:46 AM
Mustang5L5's Avatar
Common issue
https://g35driver.com/forums/g35-sed...er-flange.html
I plan on cutting the flange out and having a shop weld a peice of pipe place.
I've been driving for a while with a leak, and kinda like the exhaust tone. HOWEVER, when i'm tired and at the end of the day and want to go home, the drone is ANNOYING.
I've discovered i like my cars silent now. I'm getting old
Old Apr 25, 2013 | 02:50 PM
FireGuy385's Avatar
Originally Posted by Mustang5L5
Common issue
I found this link from that post that seems promising:
https://g35driver.com/forums/intake-...ipe-saves.html
Have you given that any consideration-if not, why not?
Old Apr 25, 2013 | 02:58 PM
FireGuy385's Avatar
Thanks- Just so I am clear, in addition to those two parts, I'd need the actual muffler, correct?
Old Apr 25, 2013 | 04:17 PM
Andyl's Avatar
time for a Hks muffler
Old Apr 25, 2013 | 08:50 PM
ccc123pm's Avatar
X
^^ we dont know if you need a y-pipe (probably not), the midpipe looks alright from the picture you have given. either need the joint cut out and weld in a new piece of pipe or replace the whole muffler section.
Old Apr 26, 2013 | 10:25 AM
psedog's Avatar
Back in SD**
Holy crap. Luckily mine are still nice. I swap between my muffler and straight pipes every year for inspection. Glad I know of this problem now. Will some high temp paint help with this? A few bucks in paint to save hundreds later... I'm more worried about the midpipe than the exhaust.
Old Apr 26, 2013 | 12:57 PM
Mustang5L5's Avatar
I bought the parts to do this repair, but the way my flange rusted out, i don't think it's going to work. The rust actually took out a bit of the lip too. So i'm sure i would be able to get it to clamp up and hold, but I think i'd still have a leak.
Since i have zero desire to change my exhaust..i'm at the point where i'll just tell a shop to weld in a 6" pipe and call it a day.
Muski_G
Dec 1, 2023 11:11 AM
RA102223
Aug 15, 2015 09:24 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
